ilanitohuevofrito , via OnePlus Community App , May 8, 2022 : I moved to the CE2 from the OnePlus 7. On my previous phone, the VPN just connected silently and left a key logo in the top right. However using the same software, the Nord CE2 5G makes an annoying ping and then leaves a permanent notification on top of the key logo in the top right. Is there any way of just having a silent VPN as I had in the OnePlus 7? Thank you.
Sourav_Satvaya , May 8, 2022 : This notification is from Android System you can't permanently remove it but you can hide it. Go to your VPN's app info then select notifications and turn off notifications. This will hide the notification but will retain the key icon on the status bar.
