" waiting to backup " problem
  1. Suhas Rahul Donut May 17, 2019
    Suhas Rahul, May 17, 2019 :
    Is there any way to fix the problem for "backup now* under the backup option which is not available. help me fix the problem by providing the solution thank you.
    MP_Kiwi likes this.
  2. Roger.T Jelly Bean May 17, 2019
    Roger.T, May 17, 2019 :
    This is done via Google.
    Sometimes it takes time for the servers to respond...
    Kytharsis and Suhas Rahul like this.
  3. Suhas Rahul Donut May 17, 2019
    Roger.T
    Sometimes it takes time for the servers to respond...​
    how much time does it take normally.
  4. Roger.T Jelly Bean May 17, 2019
    Kytharsis likes this.
  5. Rognar Eclair May 17, 2019
    Rognar, May 17, 2019 :
    Do you have an A6000 device for India? Then maybe the problem is in Google services. I also have problems with Backup and battery consumption
    Suhas Rahul likes this.
  6. Waveform Modifier Marshmallow May 17, 2019
  7. Rognar Eclair May 17, 2019
    Why was everything good at 9.0.3, and after updating 9.0.4, problems started?
  8. Waveform Modifier Marshmallow May 18, 2019
    Waveform Modifier, May 18, 2019 :
    I don't think that is the case. The backup is handled by Google and it is pinging a Google server. If you have an issue with the backup, go ask Google.
  9. Rognar Eclair May 18, 2019
    Rognar, May 18, 2019 :
    What is your model of the device? Likely A6003?
  10. Rognar Eclair May 18, 2019
    Delete the password from the phone, leave the unlock with a swipe. Backup will work, it may be possible to run it manually
    dantz, Kytharsis and Suhas Rahul like this.
  11. Waveform Modifier Marshmallow May 18, 2019
    Why would my device matter? Google Backup is universal and baked into Android.
  12. Rognar Eclair May 18, 2019
    Because problems are observed only on the A6000. You have A6003, so everything works for you. Many in the Russian community report problems with this model.
  13. Waveform Modifier Marshmallow May 18, 2019
    Than report it to Google. OnePlus wouldn't touch Google apps.
  14. Suhas Rahul Donut May 18, 2019
  15. Suhas Rahul Donut May 18, 2019
    Suhas Rahul, May 18, 2019 :
    latest version 9.0.13
  16. Rognar Eclair May 18, 2019
    Yes, on 6t I also met such a problem. Will advise прошивку 9.0.11
  17. Rognar Eclair May 18, 2019
    I talked about OP6, You have firmware 9.0.11. Perhaps help.
  18. dantz Cupcake Jun 25, 2019
    dantz, Jun 25, 2019 :
    Wow would have never thought about doing this. Thanks!
  19. Sylvia_39 Gingerbread Jul 22, 2019
