6
Wake up 6t Issue still
  1. Najemnik
    Eclair Jan 7, 2019
    Najemnik , Jan 7, 2019 :
    Hi
    I have the same issue with wake up my 6t even after update to 9.0.11. not always but sometimes I have to tab 4 times to wake up 6t
  2. Ashish_TYAGI06
    Cupcake Jan 7, 2019
    Pranay Rathan likes this.
  3. S.Ganesh Nag
    Froyo Jan 7, 2019
    S.Ganesh Nag , Jan 7, 2019 :
    same problem here also and the finger print scanner also hangs up some times and again it will get set back after a while. These lags and bugs are to be addressed by oneplus.
  4. Ashish_TYAGI06
    Cupcake Jan 7, 2019
    Ashish_TYAGI06 , Jan 7, 2019 :
    right
  5. brennanfurca
    Eclair Jan 7, 2019
    brennanfurca , Jan 7, 2019 :
    things with .11 have gotten bad on my device. Bluetooth and screen wake issues for sure.
  6. Gary Uppiah
    Eclair Jan 8, 2019
    Gary Uppiah , Jan 8, 2019 :
    I'm also on 9.0.11. I have not been experiencing these issues. Bluetooth still connects to 2 devices no issues, no drops. finger print scanner is also working fine.
    K1541293047381 likes this.
  7. Bobthesfd
    Donut Jan 8, 2019
    Bobthesfd , Jan 8, 2019 :
    Try going to Settings -> Utilities and turn off Pocket Mode. This should make it so that you only need to tap twice.
  8. Ajbailey21
    Cupcake Jan 8, 2019
  9. S.Ganesh Nag
    Froyo Jan 8, 2019
    S.Ganesh Nag , Jan 8, 2019 :
    but the fingerprint scanner there is an issue, you might not be using it frequently because you might be using face unlock also. keep face unlock off and try unlocking the phone and start using it and see
  10. Najemnik
    Eclair Jan 8, 2019
  11. viciovb
    Gingerbread Jan 8, 2019
    viciovb , Jan 8, 2019 :
    Same for me. Sometimes the single tap doesn't wake up the display (I need to use the power button). Other time, even if the display is on if I tap the fingerprint icon nothing happens. I need to press the power button
    A1546190420419 likes this.
  12. Pranay Rathan
    Eclair Jan 8, 2019
  13. CK_1
    Cupcake Jan 8, 2019
    CK_1 , Jan 8, 2019 :
    I'm having problems waking up the phone as well. It happens randomly, but especially first thing in the morning after charging overnight. I have double tap to wake on, but neither that nor the power button turns the screen on. I need to hold the power button down to restart the phone. I think this only started happening since the 9.0.11 update. I'm on the 6GB variant.
  14. Najemnik
    Eclair Jan 8, 2019
    Najemnik , Jan 8, 2019 :
    what's the difference 6GB or 8GB ram everything is the same. Oneplus has problem with software , screen is ok
  15. Sai_akash156
    Cupcake Jan 9, 2019
  16. eskimosound
    Gingerbread Jan 9, 2019
