15
[Submitted to Jira] Wakelock after using Bluetooth devices
  1. swa100 Froyo Dec 3, 2017
    swa100, Dec 3, 2017 :
    I was getting constant wakelocks on open beta 1 and also on the 3rd leaked close beta. It seems that the phone stays awake when Bluetooth has been used. The wakekock is gone after a reboot (with Bluetooth turned off). In my case, it was happening after playing pokemon GO with the Pokémon go plus Bluetooth accessoire. When done playing and turning off Bluetooth, the phone would stay awake. Reverted to nougat because of this.
    Edit: see: https://forum.xda-developers.com/oneplus-5/help/wakelock-upd
  2. nofoo Froyo Dec 3, 2017
    nofoo, Dec 3, 2017 :
    I experience the same.
    "Dirty" flashed the beta, and after three days of poor battery (barely 24hrs with a 100% load. 1-2hrs on screen time) i did a full wipe.
    Still battery is draining incredibly fast.
    I1511621037959 and swa100 like this.
  3. swa100 Froyo Dec 4, 2017
    swa100, Dec 4, 2017 :
    I did also dirty flash the first time, but sgyer experiencing these wakelocks, I've fully wiped the device. Didn't help unfortunately
  4. pratikdoshit Gingerbread Dec 4, 2017
    pratikdoshit, Dec 4, 2017 :
    +1, i dint know what was causing the battery drain.. then i figured out it was after i connected my phone to my car bluetooth
    swa100 likes this.
  5. Spafito Cupcake Dec 4, 2017
    Spafito, Dec 4, 2017 :
    Same here, it happend to me also with my xiaomi miband2 paired with my phone
    swa100 likes this.
  6. reylimo Gingerbread Dec 4, 2017
    reylimo, Dec 4, 2017 :
    Same here when pairing to mi band 2 and moto 360 2 gen. Back to nougat :(
    swa100 likes this.
  7. swa100 Froyo Dec 4, 2017
    Hopefully oneplus looks into this. Besides this hug, the oreo beta was great!
    nofoo likes this.
  8. il_Capitano_25 Cupcake Dec 5, 2017
    il_Capitano_25, Dec 5, 2017 :
    Unfortunately I’m facing the same problem. Of course this is a beta and you have to expect errors, but this problem makes the software currently unusable for me.
    Through the connection with my Sony SmartWatch 3 and the SmartBand my device is permanently active and drains the battery. Thus, I have a battery consumption of 15-30 percent in 6-8 hours overnight with WiFi and mobile data turn off.
    Of course the device is charged quickly but unfortunately this helps nothing if you do not come through the day because there is so much battery consumed in standby.
    nofoo likes this.
  9. stoyanovvitalii Cupcake Dec 6, 2017
  10. I1511621037959 Cupcake Dec 6, 2017
  11. C1512492038246 Cupcake Dec 6, 2017
  12. I1511621037959 Cupcake Dec 6, 2017
    swa100 likes this.
  13. strikysha Cupcake Dec 6, 2017
  14. nofoo Froyo Dec 6, 2017
    nofoo, Dec 6, 2017 :
    For me it's a fitbit charge 2.
    Also i can conform that when i disable blietooth and restart my OP5, the battery life is great.
    As soon as i enable bluetooth, it drains. Reproducable. As soon as bluetooth is active, the device is active 24/7.
    Today i had aboit 19 hours with a full charge. Two hours screen on time.
    Top users of the battery are:
    android system
    play services
    android os
  15. swa100 Froyo Dec 10, 2017
    nofoo likes this.
  16. elitistphoenix Donut Dec 10, 2017
  17. swa100 Froyo Dec 11, 2017
  18. nofoo Froyo Dec 11, 2017
    nofoo, Dec 11, 2017 :
    Sounds awesome. I would give it a try, but i'm on call at work and need to be reachable this week unfortunately.
    Now i'm really looking forward for OpenBeta 2 :)
  19. elitistphoenix Donut Dec 12, 2017
    nofoo likes this.
  20. ArmataReloaded Ice Cream Sandwich Dec 12, 2017
    ArmataReloaded, Dec 12, 2017 :
    I hope you are joking. Leaked Beta 3 is a non-officially not supported version. How can you even complain about issues in a closed beta.
