7
Wakelock Bug in Cyanogen OS 12 (CM12 S) Triggering Fast Battery Draining in OnePlus One [How to Fix]
  1. Sjiya
    Ice Cream Sandwich Apr 17, 2015
    Sjiya , Apr 17, 2015 :
    Android system drain my opo battery. This method also can fix that?
    oscarmb86 likes this.
  2. stephaneousset
    Gingerbread Apr 17, 2015
    stephaneousset , Apr 17, 2015 :
    My One was affected by the battery drain, but since the CM12S upgrade everything is back to normal. I don't know why but that the way it is!
  3. CountryBoyCRO
    CountryBoyCRO , Apr 17, 2015 :
    I don't have any problems with battery drain. Flashed COS12 with TWRP.
    But Google play services are denied in my Privacy settings.
    ayy1892 likes this.
  4. keithnyc
    Moderator Moderator Apr 17, 2015
    keithnyc , Apr 17, 2015 :
    e
    Excellent and informative post. Thanks for the heads up...
  5. ShadySpeedster
  6. ilbarone87
    ilbarone87 , Apr 17, 2015 :
    Source?
  7. Rodav
    Honeycomb Apr 18, 2015
    Rodav , Apr 18, 2015 :
    How did you turned that off ?
    tx
  8. Jasmohit
    Jelly Bean Apr 18, 2015
    Jasmohit , Apr 18, 2015 :
    File removed
  9. Xobile97
    Gingerbread Apr 19, 2015
    Xobile97 , Apr 19, 2015 :
    Still only getting ~3.5 hrs SOT with this fix, I even disabled keep awake on privacy guard. Doesn't drain battery now but still getting bad SOT, used to get 5-5.5 SOT on cm12 nightlies.
  10. arydream
    Gingerbread Apr 20, 2015
    arydream , Apr 20, 2015 :
    For stable results next or coming weeks cyanogen will send a patch for this problem
  11. gcortes4
    Cupcake Apr 22, 2015
    gcortes4 , Apr 22, 2015 :
    Can you please explain me how did you turn of the services and which applications or services? cause I have the same issue right now, and honestly im going crazy with this.
    avibored likes this.
  12. jaykoopah
    Cupcake May 2, 2015
    jaykoopah , May 2, 2015 :
    Thread has been dead for a couple days so I'm not sure if you guys already sorted this out, but I just figured out how to do it. When in privacy guard, go to the options at the top right and go to "show built in apps". I think that it was suggested to turn off wake up and stay awake under google play services? I've turned it off, but haven't tested any differences in battery life. I did notice that location services were turned on for google play services and that it was currently running... I turned it off and my phone restarted. Lol...
    Anyway, hope that helps.
  13. Evan Ryan
    Honeycomb May 3, 2015
    Evan Ryan , May 3, 2015 :
    For anyone who wanted to know how to turn off the phone screen waking up anytime you get any notification.... It's in the settings menu under Displays & Lights... then click on Ambient Display.. that should turn off the screen with all of the notifications.
    My battery life hasn't done as well as I hoped it would. I only get 3 days between charges as opposed to 4 full days I was getting before the CM12 update... By disabling the Ambient Display it does help.
  14. naveen_andrew
    Cupcake May 5, 2015
  15. heliozguard
    Cupcake May 8, 2015
  16. MrFingerIII
    Lollipop Jun 1, 2015
    MrFingerIII , Jun 1, 2015 :
    I noticed after doing a couple things my drain has gotten under control I was able to get through a day and was left at 60% that was roughly a 9 hour shift
    Today after 9 hours my phone was left at 72% so for what ever reason my phone is starting to show signs that the battery is under control and don't need to do extremes to control it
  17. krusade
    Jelly Bean Jun 1, 2015
    krusade , Jun 1, 2015 :
    Does the zip file work on other roms Based on cyangenmod as well?
  18. linuxxp
    Gingerbread Jun 1, 2015
    #38
  19. sauron.cnp
    Honeycomb Jun 1, 2015
    sauron.cnp , Jun 1, 2015 :
    I know that it does not make any sense, but I had the battery drain issue and I solved it by removing Google Play Services and downloading it again (I am on (rooted) CM12s and I did not invent this solution but followed somebody else advice)
    Now my device goes in deep sleep
    #39
  20. krusade
    #40
    linuxxp likes this.
