Wakelocks and battery drain
  1. NeoPhoenix
    Eclair Apr 16, 2015
    NeoPhoenix , Apr 16, 2015 :
    Good morning,
    for two days now, my battery drains a lot. It lost 20% charge within 12 hours (normally it would last up to 8 days) and Google-Dienste (Google-Services) is responsible for around 50%.
    https://www.dropbox.com/s/2gsmf5gygrcad5f/Screenshot_2015-04-16-09-43-48.png?dl=0
    Hence I installed a "Wakelock Detector" - and found a problem. The phone is awake 100% of the time and did not sleep a single second. Unfortunately it could not provide any information about which apps caused wakelocks since it requires root access which I don't have. I don't know about GPS but location tracking is turned off (via widget). I could really need some help.
    Kind regards
    shcxatter2 likes this.
  2. Johan2
    Gingerbread Apr 16, 2015
    Johan2 , Apr 16, 2015 :
    Disabling Wake and Keep awake for Google services in Privacy guard solved it for me.
    Broozen likes this.
  3. morencia
    Froyo Apr 16, 2015
    morencia , Apr 16, 2015 :
    Exactly the same problem bro. I have a drain in plane mode of about 10% and months ago if I switch to plane mode with 60% y woke up at 60%. Now I wake 50% and Google services (googlequicksearc process) seems to be the cause. Any suggestion?
  4. Lecter
    Ice Cream Sandwich Apr 16, 2015
    Deactivated User likes this.
  5. Farazahmed7
  6. Alivethereality
    Jelly Bean Apr 16, 2015
    Alivethereality , Apr 16, 2015 :
    download gservicefix from google play and follow instructions
    once all done, go into settings-battery and click the trash icon to refresh the stats
    Broozen likes this.
  7. TakeMyMoney
    KitKat Apr 16, 2015
    TakeMyMoney , Apr 16, 2015 :
    What does this do exactly?
    Which functionality am I losing by applying this fix?
    Will it stop syncing? I need it to sync.
  8. shcxatter2
    shcxatter2 , Apr 16, 2015 :
    you have to go to, google settings > search and now> voice > "Ok google" detection and turn it off
    vcespon and Alivethereality like this.
  9. Alivethereality
    as far as i'm concerned its only a fix
    it doesn't loose functionality just as the privacy guard fix
    just the privacy guard didn't work for me so i downloaded that one
    at least people say it doesn't, but if you loose sync you can always just reinstall the google services
    TakeMyMoney likes this.
  10. Alivethereality
    that actually could be the thing
    never thought of that one before
  11. shcxatter2
    That's what is responsible for the phone being constantly awake ;)
  12. TakeMyMoney
    KitKat Apr 16, 2015
    Thanks. Will give it a try.
  13. Alivethereality
    well shit where were you before ?
    now i have exodus and have no such dirty problems
  14. Alivethereality
    Try this one first :
  15. TakeMyMoney
    KitKat Apr 16, 2015
    I had to shut that one down after the previous update already so that is not the problem for me. I'll try the gfix.
  16. NeoPhoenix
    Eclair Apr 16, 2015
    I uninstalled some apps and deactivated Google-App (that search thing). Google-Services does not appear anymore but Google- Play-Services and Android-System takes a lot of battery - dunno if that's normal. I didn't need the Google search bar but does Google-App has other functions besides that search bar which I might require?
    I also find it strange that the battery drain started just 2 days ago - the phone didn't have that kind of problem before. @shcxatter2 where to find google settings and privacy settings?
  17. shcxatter2
    Google settings is like an app in the app drawer, the privacy guard is in the phone's settings under privacy :D
  18. Niels_Andersen
    KitKat Apr 16, 2015
    Niels_Andersen , Apr 16, 2015 :
    Find every solution there is to prevent the battery drain in my combined battery drain issue thread on my signature.
  19. NeoPhoenix
    Eclair Apr 16, 2015
    Thanks, I found it. I couldn't deactivate the "Ok Google" detection, maybe because I deactivated that Google-App.
    @Niels_Andersen thanks. I tried #1 and #2 but the wakelocks are persisting. I really don't know what to do anymore.
    Edit: I uninstalled the Google Play-Services updates + Privacy guard fix. At least my phone can go to sleep now :) Haven't got long term results yet but it looks promising. Do I have to do something to prevent Google Play-Services from updating?
  20. weresloth
    Honeycomb Apr 16, 2015
