30
Want a long and fast charger for your OPO?
  1. epo916
    Gingerbread Aug 31, 2014
  2. Aaahh
    Marshmallow Aug 31, 2014
    Aaahh , Aug 31, 2014 :
    I'm going to wait it out...
  3. Skf123
  4. Skf123
  5. Aaahh
    Not enough to convince me not to use it.. but i keep it away from my body at all times anyways, i dont want cancer
    bestlands likes this.
  6. vmk2310
    Jelly Bean Aug 31, 2014
    Aaahh likes this.
  7. LAD2014
    Honeycomb Aug 31, 2014
    LAD2014 , Aug 31, 2014 :
    Nice one :)
    I find the OPO stock cable works fine for me and to my pleasant surprise charged my OPO very quickly! Took around 45 mins from 11% to 90%!
    I'll definitely keep the link saved for Amazon as the stock cable is a bit short (not that it matters much to me) but that longer cable could definitely be handy, not just for the One Plus either.
  8. narceoneplus
  9. provolino
    Gingerbread Sep 1, 2014
    provolino , Sep 1, 2014 :
    I love you, thanks for the discover :D
    Buying some of them :D
    Two questions:
    1 - Is the cable long 180cm/6ft?
    2 - Any difference between the one sold by Amazon at 4.05 and the one sold by partners at 3.15?
  10. Skf123
    Marshmallow Sep 1, 2014
    Skf123 , Sep 1, 2014 :
    I just measured the cable and it's 178cm from the bottom of the charger to the tip of the micro usb cable.
    I personally purchased from a 3rd party seller on amazon for £3.89 they were called Accessory Village but i think they only sell it on ebay now for a slight mark up http://www.ebay.co.uk/itm/Genuine-B...ories_MobilePhoneChargers&hash=item1e8a3f22ef i would think al of the ones on Amazon are the same but obviously i can't guarantee that. If you want to be extra safe go for the one dispatched by Amazon
  11. Skf123
    Damn that's fast but there must be an error as it's impossible for the stock OPO charger to charge the OPO that fast even if it outputted the full 2.1A that's stated on the charger. If you're certain it went up that high in 45 minutes then it must be a bug with the charge stats
  12. bestlands
    KitKat Sep 1, 2014
  13. bestlands
    KitKat Sep 1, 2014
    bestlands , Sep 1, 2014 :
    L
    What happened to your oneplus
  14. Aaahh
    Aaahh , Sep 1, 2014 :
    I still have it, but it has a faulty battery about to fail
  15. provolino
    Thanks friend for the quick reply ;-)
    If I can bother you again, what about the clip to change socket? Is it reliable?
    Is it possible to have some pictures?
  16. Skf123
    The clip to change sockets are reliable, i only use the UK one and have had no problems with it whatsover in the past few months i have owned it (originally bought it for my nexus 5).
    I just took some pictures for you
    Another advantage of this charger over the stock charger is if you're in the UK like me then you have to put up with the 2 to 3 pin adapter so it's quite abit longer than the BB charger as you can see in the picture below
  17. provolino
    Really thanks for your kindness, I appreciate the time you spent to take pictures ;-)
    I noticed the clip mechanism has a release button and this comfort me since on cheap chargers with the same system (usually without a lock/release mechanism) it's easy to have the socket plug slip away.
    Luckily (or unluckily, it's a matter of point of views :p) I'm in Italy so I didn't know they don't give you a native UK plug but just an adapter, anyway I travel to London quite often so the ability to change the head is a good plus for me :-D
    Time to get the charger now, I'll take 2/3 of them just to be sure :-D
  18. Skf123
    It's no problem. I included the lock mechanism in the picture so you understand how it works, you won't have any problems with the socket sliding off.
    If you're buying from a 3rd party seller on amazon i would just order one to start with just to check it out and see if it's the genuine product or not and then you can order the rest as it's free shipping anyway. If you're buying the one fulfilled by amazon then you might as well order enough to meet their free delivery criteria
    #38
  19. psymin
    Honeycomb Sep 1, 2014
    #39
  20. Haymond
    Ice Cream Sandwich Sep 1, 2014
    #40
