30
Want a long and fast charger for your OPO?
  1. craigtp
    Cupcake Nov 26, 2014
    #81
  2. oscarw
    Gingerbread Dec 4, 2014
    #82
  3. Serbian Overlord
    KitKat Dec 4, 2014
    #83
  4. manishv
    Honeycomb Dec 26, 2014
    manishv , Dec 26, 2014 :
    when i use this blackberry chager static electricity is being produced on the screen (if i touch the screen while charging i can sense the current) is this a problem??
    #84
  5. Skf123
    Marshmallow Dec 26, 2014
    Skf123 , Dec 26, 2014 :
    I used the battery monitor widget app on play store
    Yes it definitely sounds like a problem and i would advise you to stop using it immediately. It's most likely a faulty charger.
    #85
    manishv likes this.
  6. oscarw
    Gingerbread Dec 26, 2014
    oscarw , Dec 26, 2014 :
    I know, but in the settings of the app you can set the mA retrieval method, and I was wondering wich one you used.
    #86
  7. benluca
    KitKat Dec 26, 2014
    benluca , Dec 26, 2014 :
    GREAT info, thanks for sharing. You can also get that on (US) Amazon for $6.50, free two-day shipping if you're Prime. Just scored one.
    #87
    Skf123 likes this.
  8. Skf123
    Marshmallow Dec 27, 2014
    Skf123 , Dec 27, 2014 :
    Oh ok i see what you're talking about now, i always keep it on automatic.
    #88
  9. gargeya.369
    Eclair Jan 9, 2015
    gargeya.369 , Jan 9, 2015 :
    I'm in India, I didn't find any of the cables mentioned in the forums available in India...
    I tried ordering and using Bandridge BCL4902 2 Metres Micro USB Cable...
    That didn't serve the purpose and it was slow...
    I've returned it and now came across your post....
    Fortunately, found a Blackberry International charger which is available in India..
    http://www.flipkart.com/blackberry-international-travel-charger/p/itmczap4zkyp3fjw
    Will buy it and test it...If it is the same as the one you used, it will work...Thank you..
    I know generally charging with original charger and cable makes the phone warm..
    From your experience, Will there be any problem of overheating or any problem to the phone..?
    And is the product same as the one you are using?
    #89
  10. bvandemoll
    Froyo Jan 9, 2015
    #90
  11. BobbyTC
    Gingerbread Jan 9, 2015
    #91
  12. SSCyanogen
    Honeycomb Jan 9, 2015
    #92
  13. pablogsm91
    Eclair Jan 12, 2015
    pablogsm91 , Jan 12, 2015 :
    Yeah man, totally, cables are not a big deal unless they're cheap unknown brands, but buying something for amazon original, or Anker is ok...
    My choice is always having a non-detachable charger for my room (where I need it extra long) and any other detachable cable for anything else that always goes with me, in this case the OPO is the second one, and for the first one I'm going for this baby: http://www.amazon.com/gp/product/B004OZMWUS/ref=gno_cart_title_1?ie=UTF8&psc=1&smid=AWH9OQ2LSV12U
    So if you're looking for another charger just worry about it being for an known brand (and off course genuine) and second the output of the adapter has to be 5V/1.8Amps at least if you want a similar charge as the one with the OPO cable!
    #93
    BobbyTC likes this.
  14. vedantsinghania09
    Eclair Jan 12, 2015
    #94
  15. Skf123
    Marshmallow Jan 12, 2015
    Skf123 , Jan 12, 2015 :
    My 1st OPO got quite warm/hot whilst charging (probably due to the wakelocks i had back then) but my 2nd OPO always stayed surprisingly cool even whilst charging (both with original charger and with the blackberry one). If it just gets a little warm then i wouldn't worry.
    I think the charger in your link is different from the one i have, on mine the end is yellow and the cable length is 180cm whereas the one on your link is only 90cm. It also doesn't state what the output is so not sure how fast it would charge your OPO.
    #95
  16. Skf123
    It's not so much the speed (it charges at around the same speed as the OPO stock charger anyway) it's the length of the cable on the charger that's important as i always found the stock OPO charger was too short.
    #96
  17. Oliwin
    Donut Jan 12, 2015
    Oliwin , Jan 12, 2015 :
    I like my charger - has a definite click when I hook it up, but nice to know there are other longer options
    #97
  18. gargeya.369
    Eclair Jan 13, 2015
    gargeya.369 , Jan 13, 2015 :
    Once I receive the charger....Will test it out and report back here .
    #98
  19. gargeya.369
    Eclair Jan 14, 2015
    gargeya.369 , Jan 14, 2015 :
    Received the charger....
    Disappointed, its output ampere rating is 750mah only....Returning it ..
    #99
    Skf123 likes this.
  20. Skf123
    Marshmallow Jan 14, 2015
    Skf123 , Jan 14, 2015 :
    That's a shame, it's probably for phone's with smaller batteries.
    The one i have is designed for the blackberry playbook (tablet) so that's probably why it outputs more. Try and look for one like the one in the link i put up
