[WARNING] DON'T FLASH CM 14.1 OFFICIAL NIGHTLY IF ON 3.2.7/3.2.6
Thread Status:
Not open for further replies.
  1. sarthak61199
    Froyo Nov 10, 2016
    sarthak61199 , Nov 10, 2016 :
    I flashed cm 14.1 nightly.
    and guess what..
    My official TWRP got wiped and I had to flash the modded TWRP.
    It probably replaces the Firmware of 3.2.7 to the community build firmware which caused the problem.
    JUST DONT FLASH.
    ALSO CALLS NOT WORKING AS SPEAKER IN CALL IS MESSED UP
    Fahimkhan0009 likes this.
  2. Mr. BG
    Marshmallow Nov 10, 2016
    Mr. BG , Nov 10, 2016 :
    You could have known, since this is a known problem since, dunno, two months maybe?
  3. Lemonfleck73
    Jelly Bean Nov 10, 2016
    Lemonfleck73 , Nov 10, 2016 :
    Check out Info's before you stupid flash anyone's Rom, have have change my TWRP via ADB (15 sec.) and flash the Nightly (9.11),ooengapps "nano" and Boeffla-Kernel for CM 14.1. I can use my Phone (In-/Out)Calls and have no other SIM or Provider-problems... don't forget, it's a early CM-Rom and only together we can erase OS and Phone-Problems if we now about these :)
  4. SunSpear
    Ice Cream Sandwich Nov 11, 2016
    SunSpear , Nov 11, 2016 :
    Any issues using Boeffla with the 14.1 nightly? I see Boeffla's website only has a kernel for 14.1.
    Thanks!
  5. Lemonfleck73
    Jelly Bean Nov 11, 2016
  6. shatadrusp
    Honeycomb Nov 11, 2016
  7. gaster
    Lollipop Moderator Nov 11, 2016
    gaster , Nov 11, 2016 :
    How is the cm14.1 official nightly for you? Is it fast, smooth and stable for a daily driver? How about the camera?
  8. Hexxer
    Froyo Nov 12, 2016
    Hexxer , Nov 12, 2016 :
    Better than OOS in all views. BUT - O+ should bring the camera out to CM. Perfroamce is equal, Battery life is better....we need the camera. But i guess Oneplus will never give that out because there are some beef with Cyanogen
  9. musicanstefan
    Gingerbread Nov 16, 2016
  10. musicanstefan
    filipe.aparicio and Jole7 like this.
  11. Rediwed
    Rediwed , Nov 16, 2016 :
    Is it possible to flash CM14.1 while retaining data from OOS 3.2.6?
    I tried it but it returned error 7 (can't install on top of existing data).
  12. mrambriz
    Honeycomb Nov 17, 2016
  13. Jole7
    Gingerbread Nov 17, 2016
    Jole7 , Nov 17, 2016 :
    Not possible different android versions.
  14. Rediwed
    Gingerbread Nov 23, 2016
  15. nunopinho1982
    Lollipop Nov 23, 2016
    nunopinho1982 , Nov 23, 2016 :
    Looooooooooooooooooooooooool
    You can flash with twrp wng.stk or grarak
    Before install ,search official nightlies thread in xda
  16. AloCubano
  17. Jole7
    Jole7 , Nov 23, 2016 :
    No clean flash is needed
    AloCubano likes this.
  18. PVS Kharoud
    Marshmallow Senior Moderator Nov 24, 2016
