2
Warp 30 wireless charger flashing red
  1. Kritacal
    Cupcake May 18, 2020
    Kritacal , May 18, 2020 :
    Anyone else get this issue? Every time I plug in my wireless charger, the light begins flashing red and it doesn't charge my OP8 pro. It worked fine for 2 weeks then all of a sudden it stopped. If I leave it unplugged for a bit then plug it back in it works for maybe 10min but then starts flashing red again. What's going on? There's been no damage to it and it's just been in one place the whole time.
    U1592547384896 and DietrichXD96 like this.
  2. alkandery75
    Froyo May 19, 2020
    alkandery75 , May 19, 2020 :
    I'm facing same issue, started after 10.5.8 update.
    I believe it has something to do with bedtime mode, I'll be doing some testing
    Chemist510 and malks022 like this.
  3. DietrichXD96
    Cupcake May 21, 2020
    DietrichXD96 , May 21, 2020 :
    I am having the same issue. This sucks, it costs a lot but it stops charging after a minute.
    malks022 likes this.
  4. malks022
    Cupcake May 22, 2020
    malks022 , May 22, 2020 :
    Yep same here. Started around a week ago. Getting very frustrating considering how much it costs.
    alkandery75 likes this.
  5. Pierretalexandre
    Cupcake May 25, 2020
    Pierretalexandre , May 25, 2020 :
    Same for me here. Struggling with my battery for a week now :( I bought this 8 pro just for the wireless charger. It was a lot of money, I should have kept it
  6. Chemist510
    Cupcake May 29, 2020
  7. Paul Fisher 007
  8. F_Tony_DeMartino_hjHI
    Ice Cream Sandwich May 29, 2020
  9. Loveit
    KitKat May 30, 2020
    Loveit , May 30, 2020 :
    Perhaps the Warp Wireless Charging has already fried the internals.
  10. thechain
    Donut Jun 2, 2020
    thechain , Jun 2, 2020 :
    I just bought op pro + warp wireless charger brand new and same behaviour. maybe 1 min or 10 mins and red light blinks stopping the charge. I tyhought it was due to the temperature of the battery for heavy usage and or the case but no changes trying to leave phone without case or cooler, simply it stops after 5-10 mins instead of 1-2 mins.
  11. Chemist510
    Cupcake Jun 3, 2020
    Chemist510 , Jun 3, 2020 :
    I unplugged my wireless charger and plugged it back in and it worked just fine. I'm using a Spigen Tough armor case.
  12. alkandery75
    Froyo Jun 11, 2020
  13. alkandery75
    Froyo Jun 11, 2020
    alkandery75 , via OnePlus 8 Pro , Jun 11, 2020 :
    Thanks mate, that's a magical solution [e]1f44d[/e]🏼
  14. ronakbarman
    Gingerbread Jun 11, 2020
    ronakbarman , via OnePlus 3 , Jun 11, 2020 :
    that case is not compatible, the reason it turns red and switches off charging because phone heats up to a certain temperature, and fan is not able to cool it, remove the case, and it will be fine.
  15. Chemist510
    Cupcake Jun 17, 2020
    Chemist510 , via OnePlus 8 Pro , Jun 17, 2020 :
    well it seems like the case that ships with the phone is not compatible also. That case sometimes makes my wireless charger blink red and stop charging.
  16. hahaha2223
    Jelly Bean Jun 17, 2020
  17. L1586033979038
    Cupcake Jul 4, 2020
    L1586033979038 , Jul 4, 2020 :
    I've been having the same problem. And taking the case off doesn't help it at all. I have tried it with a case,no case, turned off turned on with all apps closed. And I have even tried to charge it during multiple times of the day just to see if that works somehow and nothing has fixed the issue. Mine also started after the update happened
  18. varunsur
    Gingerbread Aug 19, 2020
  19. Alghazali3000
    Cupcake Sep 20, 2020
    Alghazali3000 , Sep 20, 2020 :
    Been having the same issue from day one. I have noticed that when the Bedtime mode is activated that issue disappears. Now the Bedtime mode is activated 24/7.
  20. P1601154041087
    Cupcake Sep 26, 2020
    P1601154041087 , Sep 26, 2020 :
    I am having same issue with my OP8 Pro, it happens just after 30 - 40 seconds red light starts flashing and charging stops. Any one from oneplus comment on this issue.
