171
Warp Charge 30: An in-depth look at our fastest charging tech ever
  1. tfulcher
    Donut Feb 27, 2019
    tfulcher , Feb 27, 2019 :
    ...unless you want to DRIVE with your OnePlus 6T McLaren Edition, in which case you're out of luck, because there's no car charger available. Oh, and don't lose the Warp charger they sent you, because there's also no replacement available for that. This is a massive fail on the part of OnePlus.
  2. tfulcher
    Donut Feb 27, 2019
    No. Haven't you heard - they made the cable and part of the charger orange so that you'll never lose it, because if you do, you're never going to be able to replace it.
  3. D1558983950678
    Cupcake May 27, 2019
    D1558983950678 , May 27, 2019 :
    Will the Warp charger keep my OnePlus 6t cooler while charging?
    All the info indicates that much of the circuitry to manage charging has been moved to the Warp charger - to reduce heat buildup in the 6t Mclaren edition.
    Wondering if that helps keep the regular 6t cooler when charging, than when on the Fast charger?
  4. Fingleberries
    Cupcake Jun 5, 2019
  5. molanka
    Gingerbread Jun 5, 2019
    Fingleberries likes this.
  6. Tidbits808
    Cupcake Jun 6, 2019
    Tidbits808 , Jun 6, 2019 :
    I bought the warp charge car charger and my 7 Pro just says charging. Is there a setting I need to turn on? Also I have this persistent notification to setup the charger and never goes away, and nothing to turn on warp charging in it.
  7. Kytharsis
    Marshmallow Jun 6, 2019
    Kytharsis , Jun 6, 2019 :
    Is there a lightning bolt where the battery indicator is?
  8. Tidbits808
    Cupcake Jun 7, 2019
    Tidbits808 , Jun 7, 2019 :
    yes there is. I noticed it doesn't do that warp animation that happens when I use the wall charger.
