Warp charge and usb c headphones don't work anymore
  1. Galagaan
    Cupcake Feb 3, 2020
    Galagaan , Feb 3, 2020 :
    Hi everyone !
    Since 2 days my phone no longer support my USB C headphones. I tried with another one but same thing. furthermore, when I want to charge with Warp mode, it doesn't work (with OnePlus adapter+cable). But I still can charge my phone in normal mode and if I put a double entry USB C (with jack + USB C) it works.
    Is it a known problem or is there a solution to have my Warp mode back and USB C headphones ?
    Thanks in advance !
    Freddy
  2. sd@bs
    Cupcake Feb 5, 2020
    sd@bs , Feb 5, 2020 :
    Hi everyone.
    Same issue for me especialy with my headphones, no detected when plugged.
    The only one difference with Galagaan issue is that the warp charging mode seems to work well again, without did anything.
    First I thaught it was a mecanical issue on the connector (when both were broken) but now the warp mode is up, I'm more guessing a software issue ?
    My Configuration :
    Phone: OnePlus 7 Pro
    Headphones : the basic ones provided with the phone
    Android version : 10
    Oxygen Build : 10.0.3.GM21BA
    Thanks in advance.
    Best Regards
  3. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Feb 5, 2020
    KeepTransisting , Feb 5, 2020 :
    Get some canned air and blow out your charging port. Sounds like you have some debris in there blocking a good connection for some of the pins. You can use a paperclip too if you're really careful
