Warp Charge is not working on Oneplus 7T pro Mclaren edition ! via OnePlus 7T Pro
  1. ajayy9967
    Cupcake Feb 18, 2021
    ajayy9967 , via OnePlus 7T Pro , Feb 18, 2021 :
    I'm using the Oneplus 7T pro McLaren edition. Suddenly while charging my phone, I can see that the Warp charge is not working. It is taking time to charge my phone. Earlier warp charge was working fine. All that happens after Updating 10.3.8. Can anyone help me on resolving this issue?
    oneplusfav4ever likes this.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Feb 18, 2021
    Best Answer
    Dresa91 , Feb 18, 2021 :
    Did you clean the USB port?
    Did you try using another socket, charger or cable?
    sritejkoduru and ajayy9967 like this.
  3. oneplusfav4ever
    Ice Cream Sandwich Feb 18, 2021
    ajayy9967 likes this.
  4. drl431
    Community Hero 2020 Feb 18, 2021
    drl431 , Feb 18, 2021 :
    Try cleaning out the usb-c connector on the phone. Use a toothpick or similar non-metallic probe. Look for pocket lint.
  5. ajayy9967
    Wow! Thanks for your speedy reply.
    The issue has been resolved.
    Dresa91 likes this.
  6. ajayy9967
    I appreciate your swift response.
    Automatically issue has been resolved.
    Dresa91 likes this.
  7. Dresa91
    What exactly did help you?:)
    Can you please mark the best answer? This would help others with a similar problem:)
  8. Svo2323
    Cupcake Apr 1, 2021
  9. KabeirP
    Cupcake Jul 11, 2021
    KabeirP , via OnePlus 7T Pro , Jul 11, 2021 :
    I have 7t Pro McLaren edition. For past 2 days the phone is not warp charging .it is taking way more than 2 hours to charge to 90%. Phone is update to android 11 and the latest security patch of may 2021. Also during charging the lightning bolt symbol on the status bar is missing . What could be wrong pls advice. I am using the original charger that came with the box. Also I cleaned the UsB ports. Please help.
    tybo27 likes this.
  10. tybo27
    Eclair Jul 28, 2021
  11. sritejkoduru
    Ice Cream Sandwich Jul 28, 2021
    sritejkoduru , Jul 28, 2021 :
    @Dresa91
  12. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 28, 2021
    Dresa91 , Jul 28, 2021 :
    Did you enable optimized charging in the settings?
    Did you test your charger and cable with another OnePlus phone?
    Did you test another OnePlus charger and cable with your phone?
  13. KabeirP
    Cupcake Jul 28, 2021
    KabeirP , via OnePlus 7T Pro , Jul 28, 2021 :
    Did everything from cleaning of port and cable and adapter and tested them with other OP phone. On top of that I discovered another problem now . While charging the phone and switching it off the click vibration which happens when connecting the charger, that vibrate happens continuously when I touch the phone or pick it up. It seems the charging stops and then as soon as I pick it up that short vibrate happens again and it goes on continuously like connecting and disconnecting again and again. Don't know what's happening here.
  14. Dresa91
    What was the result of charger test?
    Did you test it in safe mode ?
    Did you reset your phone?
  15. KabeirP
    It worked fine with other phones. And I have not tested it in safe mode and have not reset my phone.
  16. Dresa91
    Could you please do it? Just to be sure.
    But it looks like a hardware issue
  17. KabeirP
    I am not in a position to reset my phone I can wipe cache and try charging in safe mode. It that doesn't help I guess I will have to go for a new adapter and cable. Just to be honest no offence but I really regret buying this phone wasting 60k rupees. Ever since I have bought this phone there's always one or the other problem mostly with software update.
    Thanks anyways.
    Appreciate your help.
  18. Dresa91
    Well,… look: if your charger works with other OnePlus phones, a new charger and cable probably won’t help.
    As I said: I guess it is a hardware issue,…
    But to sort it out, safe mode and a reset would be great,…
