7
Warp Charge is not working
  1. X1561450688286
    Cupcake Oct 13, 2019
    X1561450688286 , Oct 13, 2019 :
    Hi All,
    I'm using Oneplus 7 pro. Suddenly while charging my phone I can clearly see that Warp charge is not working. It is taking time to charge my phone. Earlier warp charge was working fine. Can anyone help me on resolving this issue?
    Regards,
    Lalith
  2. #2
  3. camohan
    Assistant Head Moderator Assistant Head Moderator Oct 16, 2019
    camohan , Oct 16, 2019 :
    Could you guys check if the charging port is clean and the wires fits in properly with the charging port.
    If yes, try using another charger cable or adaptor and if it works, either of it is faulty.
  4. jmbrownr
    Cupcake Oct 16, 2019
    jmbrownr , Oct 16, 2019 :
    Same actually. I didn't charge my phone Sunday night but when I put it on Monday morning, I noticed it wasn't fast charging. I checked the cords, switched them around, cleared the cache, and all that. Yet, my 7 Pro won't fast charge. Nothing happened to the brick nor the cord so I assume this is a software issue?
    E1590675465211 likes this.
  5. camohan
    How much time does it show to full charge and do you get the thunder icon when charging?
  6. jmbrownr
    It gets the icon but it's not charging anywhere as fast as it did before. Plus when if it was fast charging, I could feel it getting a little warmer but it hasn't been doing that.
  7. camohan
  8. UnicornZ
    Ice Cream Sandwich Oct 17, 2019
    UnicornZ , via OnePlus 7 Pro , Oct 17, 2019 :
    Ok. I am scratching my head for past two days. Before updating to 10.0.1 my oneplus 7 pro with warp charger goes from 0 to 100 in flat 64 minutes. Never took a minute more. After updating to 10.0.1, its taking 85 minutes to full charge. I don't have any problematic app that could be an issue.
    Oneplus. Please check on this.
    JNiemi likes this.
  9. Labrador62
    Cupcake Oct 19, 2019
    Labrador62 , via OnePlus 7 , Oct 19, 2019 :
    Same Problem to me...
    My OnePlus 7 does not work with Warp Charge....
    It take to long Time to charge the Phone.
    all that happens after Updating to Android 10....[e]1f609[/e]
    So, what is to do.....??
    H1571758859483 and JNiemi like this.
  10. #10
    H1571758859483 likes this.
  11. JNiemi
    Honeycomb Oct 20, 2019
    JNiemi , via OnePlus 7 Pro Nebula Blue , Oct 20, 2019 :
    I have wrote in OnePlus 7/7Pro 10.0.1 thread
    What happened your sweet talks with warp charge?
    '' Warp Charge
    is now standard on the OnePlus 7 Pro, with the device offering a 30W wall plug and requisite cable in the box. ''
    After update v10.0.x, warp charger from a box offers only 6.514W (5.17V @ 1.40 amps (power factor 0.9)) of "warp" charge. This low charging issue was detected on Beta 1 and still occurs.
    I dont know other OP7 users, but I want that power what I have been purchased.
    Im waiting will anything ever happend, this slow charge was present in DB1 Android 10, so there have been months and months time to investigate this, but nothing have been done.
    C1548311924846 likes this.
  12. Q1571786366193
    Cupcake Oct 23, 2019
  13. UnicornZ
    Ice Cream Sandwich Oct 23, 2019
    UnicornZ , via OnePlus 7 Pro , Oct 23, 2019 :
    This is what I noticed. After 30 percent it drastically dropping the power intake..
    Till 25%. True warp charging
    After 30% drop in power intake
    It gets worse
  14. Imrankhan6055
    Gingerbread Oct 23, 2019
    Imrankhan6055 , via OnePlus 7 Pro , Oct 23, 2019 :
    You're charging scale is fine.The amps decrease as the battery level increases.To prevent the battery from exploding and provide longer life. The battery speed being reduced. It would take more time from 90-100%.your phone is perfect don't worry!
  15. UnicornZ
    Ice Cream Sandwich Oct 26, 2019
    UnicornZ , via OnePlus 7 Pro , Oct 26, 2019 :
    I understand what you are saying. But this is not the case when the phone was in Android 9. After 50% it took only 35 minutes to reach 100% whereas with android 10 it takes about 1 hour to charge the second half. Difference is very noticeable. I see many users have the same problem
  16. kartishrakhunde
    Cupcake Oct 30, 2019
  17. oliicole
    Donut Oct 31, 2019
    oliicole , via OnePlus 7 Pro , Oct 31, 2019 :
    I have had this issue on my previous OnePlus 6T. It ended up being the cord.
    If you can, check that no pins are disrupted as an extra pin tells the phone that it is "fast" or "warp" charging.
    If you can, try a different cube or a different cord. Maybe even another outlet.
  18. J1577343010703
    Cupcake Apr 10, 2020
    J1577343010703 , Apr 10, 2020 :
    I am facing the same problem with my one plus 7 pro now. Suddenly since yesterday my phone stopped warp charging. I charged twice and it takes a very long time now. Has this problem been solved yet?
  19. [email protected]
    Cupcake May 28, 2020
    [email protected] , May 28, 2020 :
  20. [email protected]
    X1588670942045 likes this.
