Warp Charge is not working via OnePlus 7 Pro
  1. Glady c sekhar
    Cupcake Apr 19, 2021
    Glady c sekhar , via OnePlus 7 Pro , Apr 19, 2021 :
    My Warp charging is not working. Charging normally. Original charger and cable being used and plug it in diferent places in my house .Kindly advise me what needs to be done in this case. Thanks in advance.
  2. J4t1np4r3kh
    OnePlus Accessory Tester Apr 19, 2021
    J4t1np4r3kh , Apr 19, 2021 :
    Firstly clear your charging port to ensure there's no dirt/debris.
    Check the same for the charger wire.
  3. drl431
    Community Hero 2020 Apr 19, 2021
    drl431 , Apr 19, 2021 :
    Hi, clean out the usb-c connector on the phone. Use a toothpick or similar non-metallic probe. Look for pocket lint.
    Artemus., J4t1np4r3kh and Tokolozi like this.
  4. Steps Parku (DJ STEPS)
    Gingerbread Apr 19, 2021
    Steps Parku (DJ STEPS) , Apr 19, 2021 :
    You can as well make sure the cable is properly inserted or fixed at the USB c charging port of the phone. and check the USB break for a tight connection. If not you might want to consider checking if there's no low voltage in your electric system. or perhaps the cable is just damaged. maybe time to get a new one. if you have anyone that uses a oneplus device that supports dash charge, just use their cable and charger break to confirm.
    Artemus. likes this.
  5. lyluxlaw
    Cupcake Apr 20, 2021
  6. Steps Parku (DJ STEPS)
    Gingerbread Apr 20, 2021
    Steps Parku (DJ STEPS) , Apr 20, 2021 :
    try booting into recovery and clear cache.
  7. Suyash013
    Cupcake Apr 21, 2021
  8. lyluxlaw
