8
Warp Charge issue via OnePlus 7 Pro
  1. Abrar_Ahmed_OP
    Cupcake Nov 12, 2019
    Abrar_Ahmed_OP , via OnePlus 7 Pro , Nov 12, 2019 :
    Hi OnePlus Team,
    The latest Android 10 update on my OP7 pro has slowed down the phone significantly and lately the charging speed has also reduced a considerable amount. Previously my phone would full charge within an hour, now it takes close to 1 hr 40 mins for a full charge.
    Please help resolve this issue as soon as possible.
    Thanks
  2. F_Soner_Gezgen_qloA
    Cupcake Nov 13, 2019
  3. kresimiros
    Cupcake Nov 22, 2019
    kresimiros , Nov 22, 2019 :
    same issue on my OnePlus7 pro, since the latest Android 10 update. Same charger same cable, same phone, change android 10.0.2
    bbelow and Abrar_Ahmed_OP like this.
  4. ABCRafa
    ABCRafa , via OnePlus 7 Pro , Nov 22, 2019 :
    As always ... the technical service disappears. His knowledge is limited to a Hard Reset. A Reboot and go ... If the problem is not solved ... Hard Reset ..
    Abrar_Ahmed_OP likes this.
  5. Mohammed Anash
    Cupcake Dec 3, 2019
    Mohammed Anash , Dec 3, 2019 :
    me too facing the same problem on my one plus 7pro.. one full charge takes 3hours after the 10.0.2 update.. pls tel me the solution
  6. H1572704236256
    Cupcake Dec 9, 2019
    H1572704236256 , Dec 9, 2019 :
    my OnePlus 7T stoped warp charging since 2 days...
    it is taking more than 2 hrs to charge...
    please suggest how to overcome this problem. .
  7. sumanth.lives
    Cupcake Mar 9, 2020
    TheFunkSoulBro likes this.
  8. TheFunkSoulBro
    Cupcake Mar 9, 2020
  9. rehannali
    Froyo Apr 7, 2020
  10. iamsiddhant_t
    Froyo Apr 8, 2020
  11. U1581213970851
    Cupcake Apr 19, 2020
    U1581213970851 , via OnePlus 7 Pro , Apr 19, 2020 :
    I'm using Oneplus 7 pro(OnePlus 7 pro warp charging not working correctly). Suddenly while charging my phone I can clearly see that Warp charge is not working. It is taking time to charge my phone. Earlier warp charge was working fine. Can anyone help me on resolving this issue.
    pls make clear this problem as much as possible
  12. G1588631844918
    Cupcake May 4, 2020
    G1588631844918 , via OnePlus 7T , May 4, 2020 :
    Avoid using phone when plugged in for charging, the update is designed to stop overheating the phone or battery due to warp charge. Try airplane mode charge for a few days and do not use while charging. Will resolve this issue for sure.
