Warp Charge not working on McLaren Edition 6T? via OnePlus 6T
  1. rmendez011
    Gingerbread Dec 28, 2019
    rmendez011 , via OnePlus 6T , Dec 28, 2019 :
    Hello everybody, I require some assistance. My OnePlus 6T McLaren Edition isn't charging to warp charge specifications. I say this because in ampere the highest I see the phone charge upto is 3700 mA which is around 17~watts, I'm no wizard but shouldn't that be closer to around 5000+mA? since Warp Charge is 5V @ 6 amps 30watts?
  2. X1546337867820
    Cupcake Dec 28, 2019
    X1546337867820 , Dec 28, 2019 :
    The charging icon is showing a lighting bolt. Does your phone show the WARP circle on your lock screen?.
    Try timing your phone, how long does it take to charge?
  3. rmendez011
    rmendez011 , Dec 28, 2019 :
    Yes it does show the Warp Circle on the lockscreen but I feel like it takes closer to 1hr 30mins to charge completely. I have not timed it exactly.
  4. X1546337867820
    Cupcake Dec 29, 2019
    X1546337867820 , Dec 29, 2019 :
    Try timing it to see how long it takes, if you can, check multiple times to see if the percentage rises at the same pace, or if it is faster at a certain point, my McLaren charges rapidly till 70% then it starts to charge slowly untill 100%.
    rmendez011 likes this.
  5. gwjansen
    Gingerbread Dec 29, 2019
    gwjansen , Dec 29, 2019 :
    It's not loading at the warp specified current, but it is loading 'rapidly' as you can see by the lightning icon.
    Just checking: are you using the original warp charge cable? What is the text on the lock screen? Charging / Charging Rapidly / Warp Charging / ???
  6. rmendez011
    Gingerbread Dec 30, 2019
    rmendez011 , via OnePlus 6T , Dec 30, 2019 :
    I will do that eventually.
  7. rmendez011
    It does show the Warp Charge on the lockscreen and I do have a lightning icon in the status bar, and I am using the OEM Charger and cable.
  8. L1577992191889
    Cupcake Jan 2, 2020
    L1577992191889 , Jan 2, 2020 :
    WARP charge also doesn't work on my 6t McLaren. Charging is limited around 3800 mA.
    OnePlus need to check that out. I'm on 10.3.0.
  9. rehannali
    Froyo Jan 2, 2020
    rehannali , Jan 2, 2020 :
    I'm using 6T McLaren and at 10.3.0. Warp charge isn't working. Although it shows warp charge sign but charge at speed of dash charge.
  10. gwjansen
    Gingerbread Jan 2, 2020
  11. rmendez011
    Gingerbread Jan 4, 2020
    rmendez011 , Jan 4, 2020 :
    I wonder if OnePlus is lowering charge speed McLaren 6T's due to their age? Anyone have a OnePlus 7 PRO, 7T, or 7T Pro show their ampere charging speed on warp charge?
  12. gwjansen
    Gingerbread Jan 5, 2020
    gwjansen , Jan 5, 2020 :
    You would either have to determine battery health or use one of the in line USB current display device to make sure. I'd just report this like I suggested above, I'm not doing that because I have a 6T (which performs excellent with the update btw).
  13. aenews
    KitKat Jan 5, 2020
    aenews , Jan 5, 2020 :
    Have you tried checking the charging rate when the device is around 0-15%? On the 7 Pro, Ampere has me steadily 5000+mAh when I'm at 20% Battery.
  14. rmendez011
    aenews likes this.
  15. gwjansen
    3750 is 3/4 of 5000 - almost 3700. The 7 Pro when charged at 50%, 60%, 70%, 80%, 90% - to what current does the warp charger throttle down? It’s almost like the warp charge on the 6T McLaren ‘thinks’ the battery is almost full or it is out of the temperature range.
