Warp Charge Not Working via OnePlus 7T
  1. bobbyshrestha
    Cupcake Oct 20, 2021
    bobbyshrestha , via OnePlus 7T , Oct 20, 2021 :
    My OP7t has stopped warp charging. It does charge, but it's very slow. While charging, once in a while the dash charge icon
    does come up for a sec or two. But it doesn't charges properly, I checked the cable with other phones. I see no problem there. So is this a software issue or the USB C port is damaged. I had been using a non OP wired headset. Can this cause such issue?
    Need Help!
  2. ghostofcain
    Marshmallow Oct 20, 2021
    ghostofcain , Oct 20, 2021 :
    It's unlikely to be the non OP headset that's causing the issue. I assume you've tried cleaning the port, with a non metallic, toothpick or similar?
  3. bobbyshrestha
    Cleaned both the Port and Cable, the problem still persists.
    Sometimes it's shows Charging Rapidly, but I checked the ampere app which shows it's measuring 1000 mA - 1300 mA. That's very low for rapid charge. I also disabled Optimized Charging
