Warp Charge on a 60w cable
  1. G_Jacob_O'Brien_byiF
    Cupcake Aug 30, 2019
    G_Jacob_O'Brien_byiF , Aug 30, 2019 :
    So I needed a spare cable for my OnePlus 7 Pro. I know warp charge works at 30w, the cable I bought is USB 3.1 Gen 2 and certified for 60W of power delivery and I'm using the Dash Charge plug. Why can't I warp charge ?
  2. pablofg1978
    Spanish POC Assistant Head Moderator Aug 30, 2019
    pablofg1978 , Aug 30, 2019 :
    Because oneplus uses a proprietary cable for warp charge. You need the original cable and charger
    p0seidon94 and Starcommander like this.
  3. Starcommander
    Lollipop Aug 30, 2019
    Starcommander , Aug 30, 2019 :
    Power ratings can be deceptive.
  4. G_Jacob_O'Brien_byiF
    In what way ? It's an Anker cable so it's a reputable brand. At maximum capacity Warp Charge is 30w and this cable can provide 60w at a maximum.
  5. Starcommander
    There may be some other factors apart from 30W. Afaik the official cable is also capable to transfer the heat from phone to charger. The materials used to get 30W may be different.
  6. G_Jacob_O'Brien_byiF
    I'm no electrical engineer or anything but I fail to see how a different material of conduction would affect power delivery. It's also highly likely they are both copper.
  7. pablofg1978
    Is a proprietary cable. Inside of the cable it has something that enables this feature. A third party cable won't work (except if it advertised).
    G_Jacob_O'Brien_byiF likes this.
  8. G_Jacob_O'Brien_byiF
    Okay thank you.
  9. Mikey_1273
    Gingerbread Aug 31, 2019
    Mikey_1273 , Aug 31, 2019 :
    I was looking for a longer cable and sent a message to Anker as they are a very good brand. they told me none of their cables can support warp charge because of something to do with the amperage.
    I did find this item on Amazon and it's been working great for me but I seen now it's currently not available or out of stock.
    USB C Rapidly Charging Cable, iMangoo 6.6ft Type C Dash Charge Cable Wrap Charging for OnePlus 7 Pro Long Nylon Braided Case Fast Data Syncing Cord Rapid Charger Cable for OnePlus 7 6T 6 OnePlus 5T 5 https://www.amazon.com/dp/B07S7M9BVZ/ref=cm_sw_r_cp_apa_i_b7MADbBQF7D5S
  10. J1571299767082
    Cupcake Oct 23, 2019
    J1571299767082 , Oct 23, 2019 :
    So, you did get one before they went out of stock and it works? Or you're waiting for them to be back in stock to try it? I want a longer cable than what OnePlus offers in their store too.
  11. Mikey_1273
    Gingerbread Oct 23, 2019
    Mikey_1273 , via OnePlus 7 Pro , Oct 23, 2019 :
    I did get one and it works great. last I checked they were back in stock again on the US Amazon site. I might pick up another.
