warp charging for oneplus 7t via OnePlus 7T
  1. Aditya Nani
    Cupcake Nov 21, 2019
    Aditya Nani , via OnePlus 7T , Nov 21, 2019 :
    Warp charging is not working for my oneplus 7t since 11/20.it is not even showing as warp charging or charging rapidly.. I could observe after the OS upgrade to 10.6, it's started not working.. Is anyone facing the same and what would be the solution?
  2. Aditya Nani
  3. ShubinDongre
    Gingerbread Nov 22, 2019
    ShubinDongre , Nov 22, 2019 :
    Hi,
    Thank you for posting on OnePlus Forum,
    Are you using Cable Provided with Oneplus 7T or any different one?
    If you are using orginal Oneplus Cable then try checking your charger with another original Cable (ask your friends for their cable) to check whether Charger is faulty or Cable is.
  4. Aditya Nani
    Cupcake Nov 26, 2019
    Aditya Nani , via OnePlus 7T , Nov 26, 2019 :
    Yeah, the issue was with original oneplus cable.. I replaced it with new OP cable and it's working fine now.
    ShubinDongre likes this.
  5. Gobinath.bak
    Cupcake Dec 3, 2019
    Gobinath.bak , Dec 3, 2019 :
    I'm having same issue recently and unfortunately i dont have any friends using 1+ phone to try another cable. Can you please help me with this issue?
  6. ShubinDongre
    Gingerbread Dec 3, 2019
    ShubinDongre , Dec 3, 2019 :
    Hi,
    You can use some other USB C Type Cable as well for testing.
