Warp charging not working properly !
  1. G_Kaloyan_Konstantinov_G
    Cupcake Dec 1, 2021
    G_Kaloyan_Konstantinov_G , Dec 1, 2021 :
    Hi there, i need help with my One Plus Nord which i have from the moment it went out on the market several years ago.
    The rapid (warp) charging was working just fine until few months ago when it just stopped without any particular reason. I tried with another charger from my old One Plus 3, but the Fast charging was not working, and i have tried it before just out of curiosity and it had been working back then.
    I've also tried switching on and off the battery optimization. No result.
    When i plug the cable in, it used to say Warp Charging and now its not. Additionally on lock screen a message Rapidly charging was also visible just below the clock. Now, the message is constantly changing from "rapidly charging" to "charging" in every few seconds and my feeling is that the normally very fast charging of the battery has become an ordinary charging in terms of timing.
    What i also noticed is that rapid charging is non stop after around 90% of battery life again, without any particular reason.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Dec 1, 2021
    Dresa91 , Dec 1, 2021 :
    Did you also test a newer charger and cable than OP3 and clean the usb port?
    Tokolozi likes this.
  3. Tokolozi
    The Lab Reviewer - OPPO Find N Dec 1, 2021
    Tokolozi , Dec 1, 2021 :
    that's optimized charging.
    For the rest, make sure there isn't any dirt in the port or cable connectors.
    Dresa91 likes this.
  4. Dresa91
    he wrote that he turned it off
  5. Tokolozi
    Well, he turned on and off, maybe on again? who knows.
    Dresa91 likes this.
  6. Dresa91
    Yeah :D
  7. G_Kaloyan_Konstantinov_G
    Cupcake Dec 1, 2021
  8. G_Kaloyan_Konstantinov_G
    Cupcake Dec 1, 2021
    No, i don't have a newer one, but did test it with an older one, which used to work and now doesn't.
  9. G_Kaloyan_Konstantinov_G
    Cupcake Dec 1, 2021
    I cleaned it but no effect.
  10. Dresa91
    what OxygenOS version are you using?
  11. G_Kaloyan_Konstantinov_G
    Cupcake Dec 1, 2021
  12. Dresa91
    okay.
    did you test the charging behavior in safe mode?
  13. G_Kaloyan_Konstantinov_G
    Cupcake Dec 1, 2021
  14. Tokolozi
    When in the power menu, long click the power off button to reboot into safe mode.
  15. G_Kaloyan_Konstantinov_G
    Cupcake Dec 1, 2021
  16. G_Kaloyan_Konstantinov_G
    Cupcake Dec 1, 2021
  17. Dresa91
    can you perform a factory reset to rule out a software issue?
  18. G_Kaloyan_Konstantinov_G
    Cupcake Dec 1, 2021
    I could but that would wipe out all stored information, right? And that i would do as a final, final, final step.
  19. Dresa91
    Well,… you can backup your data before
  20. G_Kaloyan_Konstantinov_G , via OnePlus Nord , Dec 3, 2021 :
    I will see about that. I am sending a link to the logs which I made with the guidance of the support team. I don't know if this is going to be useful right now.
