5
Warp charging not working
  1. G_Sarwat_Khan_hSwX
    Eclair Feb 28, 2019
  2. Logancd1
    Ice Cream Sandwich Feb 28, 2019
    Logancd1 , Feb 28, 2019 :
    What are you plugged into to charge? I want to rule out any other external issues to help narrow down the problem. To clarify, I'm looking for what your wall charger is plugged into. Is it plugged into a surge protector of some sort, or directly into a plug in the wall, or..?
    EDIT: Also make sure neither end of the cable is dirty, filled with lint, etc. Verify the same for the charging port on the device as well as the plug on the wall charger.
  3. G_Sarwat_Khan_hSwX
    Eclair Feb 28, 2019
    G_Sarwat_Khan_hSwX , Feb 28, 2019 :
    I tried again by plugging the charger directly into the wall socket but no change. Have already done a hard reset on the phone.
  4. G_Sarwat_Khan_hSwX
    Eclair Feb 28, 2019
  5. Logancd1
    Also tried? Meaning you weren't at first? Only OnePlus charging products will allow for OnePlus's fast charging. This means you must be using a OnePlus charging cable AND a OnePlus charging brick/wall adapter.
    Deactivated User likes this.
  6. G_Sarwat_Khan_hSwX
    Eclair Feb 28, 2019
    X1582811390717 likes this.
  7. felipemendes
    Jelly Bean Feb 28, 2019
    felipemendes , Feb 28, 2019 :
    That is strange indeed. I assume you are saying that warp charging is not working because of the icon, correct?
    Had you tried to measure current in? I suggest an app called Ampere to measure charging speed.
    As reference, when I use dash charging, it starts charging at ~3500 mA. My regular charger goes up to 1500 mA. Let us know what you get.
  8. phantastar
    Eclair Mar 1, 2019
    phantastar , Mar 1, 2019 :
    I assume that's because, the environment temperature is too low.
    Remember there's a tip said dash is feasible only if the temperature of battery is above 16.5°C.
    My 6 also had no dash during night of ight January.
    Hope the information is helpful.
  9. phantastar
    Eclair Mar 1, 2019
    late January*
  10. L3m0s
    Cupcake Jun 28, 2019
    L3m0s , Jun 28, 2019 :
    I have te same problem im OP7Pro, lost warp charging after 3 days of use. Original charger and cabe, and plug it in diferent places in my house and office. It charges at 1400mah.
  11. citrus13
    Froyo Jun 29, 2019
    citrus13 , Jun 29, 2019 :
    hello. same issue with me. I was using mcclaren block and cable. and noticed today warp indicator not on so pulled out the brand new charge block and cable from the oneplus 7 pro box and plugged directly into the wall socket and no warp charging. getting what you see in my pic. any suggestions? thanks
  12. Jdefjdef
    Donut Jul 6, 2019
    Jdefjdef , Jul 6, 2019 :
    I am having this issue as well. It worked fine for about a month then just quit.
  13. G_Sarwat_Khan_hSwX
    Eclair Jul 7, 2019
    X1582811390717 and mayankrana like this.
  14. Artemus.
    Nougat Jul 7, 2019
    Artemus. , Jul 7, 2019 :
    Makes you wonder if there's something else going on. Maybe the cord?
    ironass likes this.
  15. G_Sarwat_Khan_hSwX
    Eclair Jul 8, 2019
    G_Sarwat_Khan_hSwX , Jul 8, 2019 :
    Both times this has happened now, I did notice one thing. The phone was unusually hot even when it was not plugged in. I think that's the tell-tale sign that something's wrong.
  16. D1564895691846
    Cupcake Aug 4, 2019
    D1564895691846 , Aug 4, 2019 :
    My device was supporting warp charge till yesterday morning..but suddenly now it is not supporting warp charge. Please advise me what needs to be done in this case. Thanks in advance.
    krishna_rao and X1582811390717 like this.
  17. sethiel
    Cupcake Aug 10, 2019
    sethiel , Aug 10, 2019 :
    I have the same problem. No warp charge on standard cable and charger. Need advise whats going on?
  18. Gabe_M
    Froyo Aug 24, 2019
    Gabe_M , Aug 24, 2019 :
    Warp charging stop after having the phone 7 Pro for about two weeks. Haven't measured the mA.
  19. Volston
    Cupcake Nov 28, 2019
    Volston , Nov 28, 2019 :
    Looks like update 9.0.17 had some issues. Usb pen drive is not working also wrap charging not working.
  20. Satyam008
    Cupcake Nov 29, 2019
    Satyam008 , Nov 29, 2019 :
    I'm facing the same issue but yes currently I'm in -1 to 8° temperature area.
    I think this can be one issue too.
    I'm traveling back in another 2 days let's see if this gets normal
