WARP charging not working via OnePlus 7T
  1. DrBokhare
    Cupcake Aug 17, 2020
    DrBokhare , via OnePlus 7T , Aug 17, 2020 :
    There is no fast charging working mobile takes longer time for charging.When connected to one plus charger it shows plugged in bit not charging or sometimes shows only charging.
  2. #2
  3. Manveet
    Honeycomb Aug 17, 2020
  4. DrBokhare
    Cupcake Aug 18, 2020
    DrBokhare , via OnePlus 7T , Aug 18, 2020 :
    Thanks for the reply.
    I have tried what you said but I didn't worked 😟
  5. DrBokhare
    Thanks for the reply.Sir i have tried every plug in home but didn't worked.
  6. Abhi.Dobhal
    Eclair Sep 13, 2020
  7. rmendez011
    Gingerbread Sep 13, 2020
    rmendez011 , Sep 13, 2020 :
    What does Ampere say? Download Ampere on the play store, start charging the phone while you're around 40% and show a screenshot of the app.
  8. An.I.Am
    Jelly Bean Moderator Sep 13, 2020
  9. Abhi.Dobhal
    Eclair Sep 14, 2020
    Abhi.Dobhal , via OnePlus 6T , Sep 14, 2020 :
    here it is. what does is says.
  10. rmendez011
    Gingerbread Sep 14, 2020
  11. Abhi.Dobhal
    Eclair Sep 14, 2020
    I have OnePlus 6T. When i say Warp charging i meant to say the fast charging option which we get with the phone. I am not even able to use it. in this we get the lighting symbol when it performs fast charging and the lighting symbol disappear when it doesn't. attached r the screenshots for both.
  12. rmendez011
    rmendez011 , via OnePlus 6T , Sep 14, 2020 :
    You mean Dash Charge then, I suggest you carefully clean your charger cable, and charge port, if that doesn't work, go into recovery and clear cache, if that doesn't work factory reset your phone, and finally if that doesn't work either buy a new cable and charger, or replace battery. But first try the cleaning and clearing the cache.
  13. Abhi.Dobhal
    Eclair Sep 14, 2020
    I have tried everything with my charger. Will try clearing the cache, thanks!
  14. rmendez011
    If that fails, either factory reset, buy new chargers, or replace the battery
  15. X1597726974001
    Cupcake Sep 14, 2020
    X1597726974001 , Sep 14, 2020 :
    is it possible to replace battery ? I've a OnePlus 7T, can battery be replaced ?
  16. Rajendra.Bhat
  17. rmendez011
    Yes it's possible, you just have to remove the back glass with heat, but it voids warranty
  18. X1597726974001
    And where it can be done ? I mean, Can OnePlus Service Center can replace it or it will be done only through 3rd party stores ? I'm not thinking to replace battery, my Device is still new, just a month old but only gathering ideas if battery replacement is still possible these days.
  19. rmendez011
    Oneplus Service center can replace your battery, aswell as 3rd party stores. But if you're still under warranty whenever you decide to change your battery I think OnePlus charges you less. You could also buy the battery and do it yourself following a iFixit guide.
  20. Rajendra.Bhat
