warp charging
  1. bala86vlr
    Donut Jun 23, 2019
  2. ak6693
    Eclair Jun 23, 2019
    ak6693 , Jun 23, 2019 :
    Are you using the official charger and the official cable that comes out of the box? If not, you need to use that in order to warp charge. Warp charge will not work with any other c- type cable or any other charger.
    Cervantes and bala86vlr like this.
  3. bala86vlr
    Donut Jun 23, 2019
    bala86vlr , Jun 23, 2019 :
    using original oneplus charger and cable friend but no use.
  4. ak6693
    Eclair Jun 23, 2019
    Can you see the warp charge animation on the lock screen as soon as you connect the charger?
    The animation should end and this is what should displayed on the lock screen after the animation.
    Can you see that on your phone?
  5. bala86vlr
    Donut Jun 23, 2019
    not able to see that animation friend just charge indication
  6. bala86vlr
    Donut Jun 23, 2019
  7. ak6693
    Eclair Jun 23, 2019
    That's weird. If you are using the official charger and cable, it should charge. Did it use to warp charge before of has it never warp charged?
  8. bala86vlr
    Donut Jun 23, 2019
  9. ak6693
    Eclair Jun 23, 2019
    That's unusual. I see no reason for it to stop charging all of a sudden. In that case, I suggest you take it to an offical OnePlus store and get it checked.
  10. bala86vlr
    Donut Jun 23, 2019
    sure friend. thank you for guide me.........
    ak6693 likes this.
  11. bala86vlr
    Donut Jun 24, 2019
    bala86vlr , Jun 24, 2019 :
    Friend changed the charger cable. just for your info. again thanks for your help.
    now working fine.....
    ak6693 likes this.
  12. ak6693
    Eclair Jun 24, 2019
    ak6693 , Jun 24, 2019 :
    No problem at all mate. Good to know you're up and running. [e]1f44c[/e]
    bala86vlr likes this.
  13. bala86vlr
    Donut Jun 24, 2019
    thank you
    ak6693 likes this.
  14. B1559324880802
    Cupcake Jul 2, 2019
    B1559324880802 , Jul 2, 2019 :
    I also have the same issue. It was working fine but now it's just charging in normal rate.
  15. spot01
    Ice Cream Sandwich Jul 2, 2019
    spot01 , Jul 2, 2019 :
    My phone is warp charging as it only takes 1 hour 20 to charge from 0% but I don't see any Warp Charge legend on lock screen
