7
waze won`t connect to gps
  1. like1god
    Eclair Aug 22, 2018
    like1god , Aug 22, 2018 :
    its working thanks allot.
    #61
  2. GabrielAK
    Donut Aug 22, 2018
    #62
    Mipox1959 likes this.
  3. D1534944031669
    Cupcake Aug 22, 2018
    #63
  4. Clapico
    Froyo Aug 22, 2018
    #64
  5. Leorenaud
    Leorenaud , Aug 22, 2018 :
    Until this is fully resolved, a possible solution to this issue is to activate Advanced Battery Optimization from the OnePlus' Battery Settings.
    Simply go to your phone's Settings, tap Battery and then on the 3 dots menu on the upper right and tap Advanced Battery Optimization to activate.
    And it seems that it only works with the latest Android security patch update 2018.8
    #65
    Clapico likes this.
  6. GabrielAK
    Donut Aug 22, 2018
    #66
  7. tomandco
    Donut Aug 22, 2018
    tomandco , Aug 22, 2018 :
    same here since the last update. but at least in my case the battery optimization tips solved it.
    #67
  8. Zvikaf
    Zvikaf , Aug 22, 2018 :
    Battery optimization works for OP6 in 5.1.11. What are the consequences of enabling that advanced option?
    #68
  9. Mipox1959
    #69
  10. Clapico
    Froyo Aug 22, 2018
    Clapico , Aug 22, 2018 :
    OK for me thanks
    #70
  11. Anasse
    Froyo Aug 22, 2018
    #71
  12. Gav_W86
    Starting Point Expert Aug 22, 2018
    Gav_W86 , Aug 22, 2018 :
    Ok. There have been some background changes made. If not already working, reboot and it should start working (you don't need Advanced Optimisation enabled).
    #72
    Clapico and BlueSkiesnH2O like this.
  13. vilmantasr
    Donut Aug 22, 2018
    #73
  14. Clapico
    Froyo Aug 22, 2018
    I tried, it works. Thanks
    #74
  15. BlueSkiesnH2O
    Donut Aug 22, 2018
    BlueSkiesnH2O , Aug 22, 2018 :
    Waze seems to be working again. Can someone tell us if this is a permanent fix or is it just a matter of time before it quits again?
    Glad to see OnePlus/Waze actually put some effort into fixing.
    #75
    Clapico likes this.
  16. salvaescalante
    Eclair Aug 22, 2018
    salvaescalante , Aug 22, 2018 :
    Confirmed, disable the battery optimization and then reboot,. Now Waze seems to be back to normal.
    #76
    jufran10 and Clapico like this.
  17. Gav_W86
    As far as I'm aware it is a permanent fix - though I'm not in possession of the details of what was done.
    #77
    Clapico likes this.
  18. hadox
    Cupcake Aug 23, 2018
    #78
  19. SnorkYz
    #79
  20. Gav_W86
    Starting Point Expert Aug 23, 2018
    Gav_W86 , Aug 23, 2018 :
    try clearing cache from recovery mode
    #80
