Weather / Weer app Battery Batterij via OnePlus 8
  1. sanderhuismandev
    Cupcake Oct 21, 2020
    sanderhuismandev , via OnePlus 8 , Oct 21, 2020 :
    Hello,
    The new Weather app drains the battery.
    Tryed more option.
    De nieuwe weer app gebruikt veel batterij.
    Meerdere instellingen geprobeerd.
    What ton do?
    Hoe op te lossen?
    Z1601700722952 likes this.
  2. sanderhuismandev
  3. Morganismo
    Cupcake Oct 22, 2020
    Morganismo , via OnePlus 8 Pro , Oct 22, 2020 :
    I have the exact same problem the last 2 days. The weather app kills the battery! It has more than 30% usage on a full charge without even using it!
    I hope they fix it soon...
  4. Morganismo
    Cupcake Oct 29, 2020
    Morganismo , via OnePlus 8 Pro , Oct 29, 2020 :
    I have found a temporary solution until they fix the app. You have to choose location access only while using the app and then it doesn't drain the battery.
