Web Browsers Severely Drain Battery
  1. napes22
    Honeycomb Sep 10, 2015
    napes22 , Sep 10, 2015 :
    Regardless of web browser that I use, it significantly drains battery faster then the screen itself. I've tried 3 different browsers and all have the same effect. The phone also tends to get hot when using any web browser as well.
    Has anyone else experienced this? If I use the phone for anything else it doesn't drain as much (unless I'm watching a movie or playing a game).
    I'm using the OP2 stock Oxygen 2.0.2.
  2. Cuerex
    KitKat Sep 10, 2015
    Cuerex , Sep 10, 2015 :
    chrome works the same as it did on oneplus one for me
  3. napes22
    That's not my question. My question is if anyone else finds that browsing the webs uses a ton of battery compared to other activities.
  4. anirbanbhakta
    anirbanbhakta , Sep 10, 2015 :
    This is a strange issue.
  5. skuk4526
    Gingerbread Sep 10, 2015
    skuk4526 , Sep 10, 2015 :
    I can totally confirm this!!! How many browsers have you tested?
  6. Dave ze Rave
    Eclair Sep 10, 2015
    Dave ze Rave , Sep 10, 2015 :
    Yes, I find the same thing. I use firefox.......Chrome is a hateful thing like a virus! If I use the browser I always close it straight after use or it really adds to the battery drainage
  7. Navy.seal
    Cupcake Sep 10, 2015
    Navy.seal , Sep 10, 2015 :
    For a long time, I've just use android phone again. And I feel not comfortable with chrome like safari or browser of bb10.
    Can you show me some browser app same it.
  8. napes22
    I've tried 3 so far, but I guess I'll try Firefox next. This has to be an Oxygen OS issue, since I've never had this type of problem on any other phone.
    For now I reflashed the phone and started from scratch at 2.0.2. I'll see if that helps.
    Adityaf likes this.
  9. napes22
    Do a forum or google search for "best android browser." However this is not the purpose of this thread.
  10. Magnetic Nerd
    Jelly Bean Sep 10, 2015
  11. acomp182
  12. skuk4526
    Gingerbread Sep 11, 2015
    skuk4526 , Sep 11, 2015 :
    I use CM browser as well. My personal favorite light-weight full-fledged browser. And I've noticed the CPU consumption. The CPU is in constant use as long as you're inside the app.
  13. napes22
    Honeycomb Sep 11, 2015
    napes22 , Sep 11, 2015 :
    I wonder if a custom kernel will fix this.
  14. sleepdragonone
    KitKat Sep 11, 2015
    sleepdragonone , Sep 11, 2015 :
    Just don't use browser at all on your phone, use a tablet instead, that should save you some battery.......hehe
  15. MrYoda
    Cupcake Oct 3, 2015
    MrYoda , Oct 3, 2015 :
    I can totally confirm, like on chrome/firefox, it eats the battery like hell, and it seems like its on oxygen, coz i flashed oxygen on my OPO, and it was the same, it draining it.
    Cyanogen worked perfect.... and i dunno what to do.
  16. siebica
    Donut Oct 3, 2015
    siebica , Oct 3, 2015 :
  17. ormer
    Cupcake Oct 3, 2015
    ormer , Oct 3, 2015 :
    I don't see this problem. I'm running 2.1.0, opened Firefox, battery started at 98%.
    Opened Firefox, used Google search and browsed local news. Looked at the weather, searched for Oneplus2 and opened several links. About 10 minutes of browsing, ending up at 98% battery still.
    No drain, no heating. I'm on WiFi, 5GHz. Factory stock, locked bootloader.
    Seems that if you're going to get help with this issue, you'll need to provide more details to help with duplicating it.
  18. skuk4526
    Gingerbread Oct 6, 2015
    skuk4526 , Oct 6, 2015 :
    Chrome seems to lower the battery consumption as compared to CM browser which didn't cause any problem on my Nexus 4. Can't use my favorite browser :( I know it's from Cheetah mobiles but it's a light weight full-fledged browser.
  19. mrlam2000
  20. Adityaf
    Ice Cream Sandwich Oct 6, 2015
    Adityaf , Oct 6, 2015 :
    Issue confirmed. Every browser drain more battery than my screen and that's strange. Either it's hardware issue or OxygenOS. I've tried updating webview but no success...
