What are the settings to use internet at it max speed
  1. G_Harsh_Shirbhate_roxN Cupcake Sep 13, 2017
  2. Nezumi_ KitKat Sep 13, 2017
    Nezumi_, Sep 13, 2017 :
    change ur Internet provider?
    Photoman9988 likes this.
  3. TheBassy Froyo Sep 13, 2017
    TheBassy, Sep 13, 2017 :
    Settings ~ Sim & Network ~ Preferred network type and select the Data modes you want, 4G is the fastest atm.
    Although it could just be that you have had coverage where you are.
    For WiFi, see previous post.
    Nezumi_ likes this.
  4. FiveOverEight Ice Cream Sandwich Sep 13, 2017
    FiveOverEight, Sep 13, 2017 :
    How dare you suggest a common sense approach!
    Nezumi_ and Mr. Vandelay like this.
  5. G_Ali_Subhan_Hdbl Eclair Sep 13, 2017
  6. G_Harsh_Shirbhate_roxN Cupcake Sep 14, 2017
  7. G_Harsh_Shirbhate_roxN Cupcake Sep 14, 2017
  8. Budruel Jelly Bean Sep 15, 2017
    Budruel, Sep 15, 2017 :
    Maybe if you run at the end of the street while using your op5 get higher speed 4G, and if while doing so, zigzag runs, I assure you 5G spikes.
  9. F_Terence_Quah_gSCv Ice Cream Sandwich Sep 15, 2017
    F_Terence_Quah_gSCv, Sep 15, 2017 :
    reset your phone network settings.
    maybe the APN is wrongly set.
    Google for APN for your sim provider and set it yourself.
