What case is more protective for the OnePlus 7 Pro, the Karbon Bumper case or the Nylon Bumper case?
  1. FlyingDogs
    Cupcake Jun 17, 2019
    FlyingDogs , Jun 17, 2019 :
    I have been using the case that came with the phone for the past few weeks and I did not really like the feel. I want to get one of the official bumper cases and I'm wondering what case is more protective?
    Sanyam Mehta likes this.
  2. RolandKillmon
    Froyo Jun 17, 2019
    RolandKillmon , Jun 17, 2019 :
    The Nylon bumper case has a higher lip for the camera than the Karbon one. I have the Karbon one for my OP 7 Pro and it barely has a lip, almost sits flush with the camera. Going to be returning mine. Hope that helps.
  3. FlyingDogs
    You going to replace it with the Nylon Bumper case or get a third party, or just stick with the one that came with the phone?
  4. RolandKillmon
    Froyo Jun 17, 2019
    I am currently using the one that came with the phone. Sending the Karbon Case back in return for the Nylon Case.
  5. Kaustubh_Kulkarni
    Eclair Jun 29, 2019
    Kaustubh_Kulkarni , Jun 29, 2019 :
    Did you get your Karbon bumper case replaced with the Nylon one?
    I want to buy the Nylon bumper case, but before that, I just want to check if it's a hard case or a flexi/mouldable like the stock transparent case that comes with the OP7 pro box. I wish it to be a flexi one.
  6. FlyingDogs
    Cupcake Jun 29, 2019
    FlyingDogs , Jun 29, 2019 :
    It is not flexible.
    Although the sides of the case has some flex to it.
  7. RolandKillmon
    Froyo Jun 29, 2019
    RolandKillmon , Jun 29, 2019 :
    The Nylon case is a soft back but hard plastic case. here is a case to look into that is just awesome and won't break the bank. the Nylon case will run you around 50 dollars after shipping. this case is 12 dollars and I know what your already thinking, it's a cheap case and probably not a good one. it's a awesome case, and recommend giving it a shot.
    here the link to check it out. it also have a video showing a 16 foot drop test using the case.
    OnePlus 7 Pro Case, Poetic Premium Hybrid Protective Clear Bumper Cover, Rugged Lightweight, Military Grade Drop Tested, Affinity Series, for OnePlus 7 Pro (2019), Frost Clear/Black https://www.amazon.com/dp/B07QVNX8BH/ref=cm_sw_r_cp_apa_i_.q3fDbGS7J6E9
  8. Kaustubh_Kulkarni
    Eclair Jun 30, 2019
    Kaustubh_Kulkarni , Jun 30, 2019 :
    Thank you for the info.
  9. Kaustubh_Kulkarni
    Eclair Jun 30, 2019
    That military grade case looks good and rugged. I will check for it's availability in India.
    Thank you for the update
  10. RolandKillmon
    Froyo Jun 30, 2019
    RolandKillmon , Jun 30, 2019 :
    It's a way to show off that sexy nebula blue without have a complete clear back. it's a Ice color back that doesn't turn yellow and show scratches. also good on not showing finger prints. really good case specially for the price.
  11. Sanyam Mehta
    Eclair Jul 7, 2019
    Sanyam Mehta , Jul 7, 2019 :
    Company's Carbon case/ Nylon case OR DBRAND grip case?
  12. ChefyKing
    Cupcake Mar 25, 2020 at 10:22 AM
    ChefyKing , via OnePlus 7 Pro , Mar 25, 2020 at 10:22 AM :
    Which case is this? Would you recommend it?
