what happens if i use normal charger
  1. Mehrdad201
    Eclair Mar 28, 2017
    Mehrdad201 , Mar 28, 2017 :
    Hi all friends
    as you know, one plus 3t has a dash charger with super fast charging technology that charges phone completely in 80 minutes.
    now I wanna know if I use a normal charger will it cause bad problems or corruption for the battery or not?
    because sometimes I need to charge the phone and I don't have my dash charger so I have to use my friend's chargers or in car my charger is normal.
    thanks for your comments.
  2. davebugyi
    Honeycomb Mar 28, 2017
    davebugyi , Mar 28, 2017 :
    It will charge slower, but should not hurt the battery (unless the charger is pretty low quality).
    proisgod and Mehrdad201 like this.
  3. Master_TC
    KitKat Mar 28, 2017
    Master_TC , Mar 28, 2017 :
    You can charge your phone with all chargers. The only thing is the speed of charging, nothing else...
    I often use the charger of Samsung, Acer, USB port of my computer, ....
    jauhari and Mehrdad201 like this.
  4. The1Lion
    Marshmallow Mar 28, 2017
    The1Lion , Mar 28, 2017 :
    You can charge with a "slower" charger instead of the normal charger but then the battery is "abnormal" because it wasn't charged normally :p
  5. Spectre_Nine
    Spectre_Nine , Mar 28, 2017 :
    Even with a non-dash charger it'll charge at a decent speed. I often use my OnePlus 2 charger with the 3T and it works a treat. :)
  6. Mehrdad201
    Eclair Mar 29, 2017
  7. BeautifulJoe
    Gingerbread Mar 29, 2017
  8. nick-turis
    Cupcake Mar 29, 2017
    nick-turis , Mar 29, 2017 :
    It can hurt more your battery in the sense that DASH charger has been built to not heat your phone, while other normal charges do. So I suggest you to keep using your DASH.
