6
what is this... how much does this 'OTHER' folder takes up on your phone???
  1. G_Mr_....
    Jelly Bean Mar 26, 2017
    G_Mr_.... , Mar 26, 2017 :
    Hi, when did you update & how is the internal storage? is there any unknown storage in (other folder) in your file manager, if there's no issue with storage just clean your cache partition via recovery, also make sure your doze is enabled.
  2. G_Mr_....
  3. rahuldw181
    Ice Cream Sandwich Mar 26, 2017
    rahuldw181 , Mar 26, 2017 :
    if u need to be on 7.1.1 it's not possible now. when one plus releases official ROM on their website we can flash it via ADB sideload and get back that space. we need clean installation. for now u can be on 7.0.1 and get that space.
    visit following website
    download.oneplus.net
  4. rahuldw181
  5. Adil_Reh_man
    Froyo Mar 26, 2017
    Adil_Reh_man , Mar 26, 2017 :
    if u r a gamer, most of the memory used by OBB files....which r not showing in the section 'storage n memory'
  6. Dunnow
    The Lab - OnePlus 6 Reviewer Mar 26, 2017
  7. Dunnow
    Dunnow , Mar 26, 2017 :
    Shhhhhhh why did u explain them?!
    Who will have fun now with retard threads?
  8. Dunnow
    if you tap the others you should be able to navigate with a file storage app to those files that take so much, at least, I can with LineageOS
  9. Aiwin_Manuel_
    Froyo Mar 26, 2017
  10. jatingada
    Gingerbread Mar 26, 2017
    jatingada , Mar 26, 2017 :
    i also had this issue. had to do factory reset.
    i have seen many of us has this same issue and many similar posts.
  11. SinisterShadow
  12. Sadra_Imam
  13. G_Udit_Sharma_hLHa
    Donut Mar 26, 2017
  14. Sadra_Imam
    Sadra_Imam , Mar 26, 2017 :
    download latest firmware from downloads.oneplus.net
    use adv to sideload zip file
    (basicly follow OnePlus instructions)
  15. Sadra_Imam
    from Wikipedia
    https://en.m.wikipedia.org/wiki/Android_Nougat
    Nougat introduces a system for enabling "seamless", automatic system updates, based upon and sharing some code with the implementation of similar functionality on Chrome OS. The system uses a pair of SquashFS partitions; the Android system executes from an "online" partition, while updates are applied in the background to a redundant "offline" partition. On the next boot following the installation of an update, the redundant partition is designated as active, and the device henceforth boots into the updated system. The previous system partition is kept as a backup in case of update failure, and to serve as the "offline" partition for the next update. This system removes the requirement for the device to reboot into the system recovery environment to apply the update (which prevents the device from being used until the update is complete) and also provides the ability for an update to be automatically rolled back in case of a failure. Due to the partitioning requirements of this system, existing devices will not support seamless updates. Additionally, due to the ART changes on Nougat, apps no longer need to be re-compiled upon the first boot after a system update.
  16. G_Samir_Ahmed_Wakil_cDWG
    Gingerbread Mar 27, 2017
  17. theantz
    Honeycomb Mar 27, 2017
    theantz , Mar 27, 2017 :
    Well, in that case, its best we wait for the official image to be available. Thanks for the reply !
  18. Venkat66
    Froyo Mar 28, 2017
    Venkat66 , Mar 28, 2017 :
    please see the screenshot below. the other folder mounts after 4.1.0, it was somewhere around 2.8 GB on 4.0.3 now it's more than 9 GB. No problem with available storage, but let's know what happening and how to clear this other folder. searched forum for solution. but not conclusive.
  19. mokolad
    Gingerbread Mar 28, 2017
  20. Venkat66
    Froyo Mar 28, 2017
