38
What people are saying about the OP7 Pro: Pop-Up Camera
  1. nelly1997
    Cupcake Jun 8, 2019
    nelly1997 , Jun 8, 2019 :
    unfortunately, I live in the UK.
  2. MR.BEN312
    Honeycomb Jun 8, 2019
    MR.BEN312 , Jun 8, 2019 :
    yes smooth like butter
    cozzmat likes this.
  3. Pikole
    Froyo Jun 8, 2019
    Pikole , Jun 8, 2019 :
    I read a review saying the front camera was too long for those who take selfie. I don't know what planet there were on, since the pop camera and you are just getting into position but the time it's fine.
    MR.BEN312 likes this.
  4. MR.BEN312
  5. jai.jhaveri
    Cupcake Jun 8, 2019
    jai.jhaveri , Jun 8, 2019 :
    hi
    the one plus 7 pro front camera opens up in pocket when I receive the WhatsApp video call. and even it opens in pocket for face recognition. pls help
    MohamadAsyhraf likes this.
  6. TonyTechBytes
    US Brand Ambassador Jun 8, 2019
    TonyTechBytes , Jun 8, 2019 :
    I believe OnePlus is working on an update to fix this issue.
  7. MR.BEN312
  8. mdl3v8
    Cupcake Jun 8, 2019
    mdl3v8 , Jun 8, 2019 :
    My selfie camera stopped working reliably after having the phone for two days. Fingers crossed that I have better luck with the replacement.
  9. MR.BEN312
    what a bummer! I hope that you get that resolved
  10. toastytoast1234
    Marshmallow Jun 8, 2019
  11. nelly1997
    Cupcake Jun 8, 2019
    ? abit confused... the helpful lad suggested if I lived in the USA to approach t mobile. but unfortunately I don't...
  12. Christopher Doherty
    Gingerbread Jun 8, 2019
    Christopher Doherty , Jun 8, 2019 :
    I'm gonna try and wait for OP to release one cause last year they put one out like a month or 2 after they put out the 6t for the 6t. but this plasticly one they included is so bad. it's got like "stretch marks" all over it and alot of little groves.
  13. S1557948734480
    Froyo Jun 8, 2019
    S1557948734480 , Jun 8, 2019 :
    hi, the PureGear screen curves completely edge-to-edge. I use the Tech-21 case that surrounds the edge with a lip slightly higher than the screen, providing more protection if dropped or sliding on the ground. I assume man bumper-style cases are similar. In any event, the edge of the screen protector is protected.
  14. nateavi
    nateavi , Jun 8, 2019 :
    OP calls it "Da Hulk mode".
  15. caseyk44
    Eclair Jun 8, 2019
    caseyk44 , Jun 8, 2019 :
    The puregear is ok. almost edge to edge. unfortunately there is a noticeable "dot matrix" that you can see under the the glass in high light situations. I'm assuming it's the adhesive set up. I haven't looked into it as of yet as I just had this applied. also is very prone to fingerprint
  16. MR.BEN312
    Honeycomb Jun 9, 2019
  17. Hoqmeister
    Froyo Jun 9, 2019
    Hoqmeister , Jun 9, 2019 :
    is there going to be a transparent back version to show of that mechanism working
    TonyTechBytes, Pikole and MR.BEN312 like this.
  18. MR.BEN312
  19. S1557948734480
    Froyo Jun 9, 2019
    S1557948734480 , Jun 9, 2019 :
    I do not see a "dot matrix"; mine was applied by the store and they were very good at cleaning and application.
    It is tempered glass, I do not see prints, but clean mine periodically with same lens cleaner used for glasses.
    I also use a Tech-21 case that pairs well around the curved edge of phone sides and sits slightly higher on top/ bottom edges of phone protecting face if laid/dropped on face. It has a nice "grippy" feel, and provides a more secure hold. The PureGear and Tech-21 pair nicely.
    I have used Zagg Invisishield for years; PureGear seems comparable in protection, feel, and cleanliness...but seems to have a smoother surface for finger swipes (...but I had my Zagg for a long time, to be fair).
    Anyway, I did not see many options I liked better than these when I was shopping
  20. parthdave34
    Cupcake Jun 9, 2019
    parthdave34 , Jun 9, 2019 :
    dear sir,
    please bring something new in oneplus devices which is not available in current market. All the new features were introduced by oppo mobile first. for instance pop up camera from oppo and vivo, notch from iphone.
    All the features are copied from iphone or oppo mobile. I believe that quality is far better than oppo mobile.
    thank you,
    Parth
    nateavi likes this.
