What phones have closest size to 1+X for case purchases?
  1. kalniel
    Froyo Nov 23, 2015
    kalniel , Nov 23, 2015 :
    I'm looking to get a sock for my 1+X, and wondered which mainstream phone I should use to order the case? (You often get cases listed as compatible with y phone for eg.)
    Samsung S6 seems a pretty close match?
  2. pa5t1s
    User of the Year 2014 Nov 23, 2015
    pa5t1s , Nov 23, 2015 :
    Why not buy a case designed for OnePlus X?
    Problems might be the position of the hole(s) for Camera(s) and side-buttons.
    sunilbagalur and Tokolozi like this.
  3. Gerrit Ravesloot
    Froyo Nov 23, 2015
    kalniel likes this.
  4. opticoverload
    Ice Cream Sandwich Nov 23, 2015
    opticoverload , Nov 23, 2015 :
    If it is, as you say, a sock, you'll be good with anything designed for 5 inch.
    If you're talking about a proper case, get ones designed specifically for this phone.
  5. Tokolozi
    Most Original Avatar Nov 23, 2015
    Tokolozi , Nov 23, 2015 :
    As other said if you are really looking for a case buy one that's made for the phone itself.
    sunilbagalur likes this.
  6. Baymax
    Marshmallow Nov 23, 2015
    Baymax , Nov 23, 2015 :
    You should get a case specifically made for the X. a universal pouch might be a good alternative.
  7. demomercury
    Gingerbread Nov 23, 2015
    demomercury , Nov 23, 2015 :
    I bought a neoprene pouch by shocksock for the Galaxy S6 and it fits perfectly on my OPX. The S6 is just slightly bigger.
    kalniel likes this.
  8. veratoloz2005
    Lollipop Nov 23, 2015
    veratoloz2005 , Nov 23, 2015 :
    ??? There are already plenty of OPX-specific cases and more will appear for sure. Amazon is your friend.
  9. kalniel
    Froyo Nov 23, 2015
    It's a sock case, no holes to worry about.
    There aren't any sock cases on Amazon for the OPX (in the UK at least). I did check before posting, though maybe my Amazon-fu isn't as good as it could be :) Would welcome links to recommended OPX socks.
  10. pa5t1s
  11. byno
    byno , Nov 23, 2015 :
    Some just stretch and fit, I had one for my S3 and it fits on my OPO so get one of those an you'll be fine.
    kalniel likes this.
  12. veratoloz2005
    kalniel, sunilbagalur and pa5t1s like this.
  13. pa5t1s
    Ah, oki doki :)
    LOL, ofc, Santa's coming soon :p
    Edit: a pouch...
  14. kalniel
    Froyo Nov 23, 2015
    hehe they're pouches, usually made of fibres. They look a bit like socks and you just slide your phone in and out like you would a foot in a sock :) Might be a colloquial term.
    pa5t1s likes this.
  15. byno
    Ha, the grey one above is the exact one I was on about too!
  16. Gerrit Ravesloot
    Froyo Nov 23, 2015
  17. AztecScribe
    Cupcake Nov 24, 2015
  18. Gerrit Ravesloot
    Froyo Nov 25, 2015
  19. Gerrit Ravesloot
    Froyo Nov 25, 2015
  20. IlCieco
    Ice Cream Sandwich Nov 25, 2015
    IlCieco , Nov 25, 2015 :
    The problem of pouches is that they offer no protection while using the phone.
    If your main need is phone safety, go for a silicone case + screen protector.
    Lots of silicone/hybrid shells should become available in those days too (see Amazon)
    If you want a cool case, then go for the original OPX cases (Rosewood, Bamboo, Kevlar, etc.)
