29
What's the best/most stable Lollipop ROM right now?
  1. CM12 Nightlies
    41.5%
  2. Paranoid Android
    5.4%
  3. SlimLP
    2.2%
  4. BlissPop
    10.2%
  5. LiquidSmooth
    4.8%
  6. EuphoriaOS
    5.0%
  7. Temasek's Build
    2.4%
  8. Resurrection Remix
    3.2%
  9. Vanir/Exodus
    16.6%
  10. Other (State in your comments/replies)
    8.6%
  1. ChoosyMoron Honeycomb Feb 27, 2015
    ChoosyMoron, Feb 27, 2015 :
    I was just wondering what if I shift my current Internal ROM which is CM11S to a secondary ROM in MultiRom Manager and flash this ROM as the main ROM?
    This way I'll be able to use this ROM test it out completely and if something goes wrong I can always shift to my CM11S secondary ROM by just rebooting..
    Any suggestions here guys??
  2. dylandelaaf Eclair Feb 27, 2015
    dylandelaaf, Feb 27, 2015 :
    What build did you use to get that great battery life.. I think im on the newest one and it seems to be draining rather quickly. Also fk r39 instead of r38.
  3. Shub91 Honeycomb Feb 27, 2015
    Shub91, Feb 27, 2015 :
    22nd Feb and franco r38.
    But now I have updated to 25th Feb build and franco r39. Haven't tested extensively till now, but looks like I am getting the same backup. will check and tell
  4. dylandelaaf Eclair Feb 27, 2015
    Great:) ill let my battery adjust and see what it gives me after 2-3 cycles. Really aiming for over 8hrs of SOT
    Shub91 likes this.
  5. ChoosyMoron Honeycomb Feb 27, 2015
    K tried and tested..
    Just shifted my internal CM11S to Secondary ROM via TWRP of MultiRom Manager..
    Wiped everything on internal.
    Flashed the firmware update file for lollipop ROMS
    Flashed the Exodus 25th Feb zip file
    Flashed the Gapps file
    I'm in the new ROM but MultiRom manager on the Lollipop is not able to install the kernel patch for CM12 its giving me an error. :(
    Update 1 :-
    So after the install I'm trying to swap the new Lollipop rom to secondary and making CM11S as primary again lets see :p
    Update 2 :-
    It's a success.. Finally I have CM11S as my internal OS and Exodus as a secondary OS both working fine and booting fine..yipeee...
    Update 3 :-
    CM11S is crashing big time including the network so a NO NO to this process guys..Reverting back to TWRP backup..
  6. Shub91 Honeycomb Feb 27, 2015
    This problem was bound to happen. Kitkat and lollipop have different modem files, so it was certain that there will be a network conflict.
  7. ChoosyMoron Honeycomb Feb 27, 2015
    Just wiped the internal after that and restored my TWRP backup now the internal is working with CM11S and I have Lollipop as secondary rom..
  8. marcy9487 Jelly Bean Feb 27, 2015
    marcy9487, Feb 27, 2015 :
    Do you hear the sounds inside the whatsapp chat (for example when you send a message, or when the arrows appear)?
    Since I switched to vanir-exodus i don't hear them anymore
  9. Bombfish Eclair Feb 27, 2015
    Bombfish, Feb 27, 2015 :
    Wait, is this ROM Finnish?
  10. marcy9487 Jelly Bean Feb 27, 2015
    I think it is the user that uploaded that screenshot................................
  11. takeabyte Ice Cream Sandwich Feb 27, 2015
    takeabyte, Feb 27, 2015 :
    Shitty battery on 26. I drained from 68% to 19% in about 7 hours overnight, screen off, but I did have my ambient noise app and baby monitor app running the whole time. But I have done that on KK and only lost around 30%
  12. dylandelaaf Eclair Feb 27, 2015
    So which one has a better battery life you reckon? Im trying out the latest one now.
  13. marcy9487 Jelly Bean Feb 27, 2015
    Sometimes when i receive a call it doens't light up the display, and it doesn't show the photo of the contact, does it happens also to you?
  14. Deactivated User Feb 27, 2015
    forid-786 likes this.
  15. lokesh3440 Honeycomb Feb 27, 2015
    lokesh3440, Feb 27, 2015 :
    Disable " Proxmity sensor wakeup wake up" option from Display settings. which ROM are you in ? have you come from CM 11s recently. Then flashing a modem firmware might help you as well
  16. marcy9487 Jelly Bean Feb 27, 2015
    I haven't got that option under "display"...
    I come from a cm11s flashing the bacon_firmware_update_2015_02-09 before the vanir-exodus 250215 rom and pa gapps.
  17. mctreklife Cupcake Feb 27, 2015
    mctreklife, Feb 27, 2015 :
    Been watching this rom for a week or so and finally was brave enough (lol) to flash it yesterday. I'll report back with battery life.
    I am however having an issue with immersive mode. It isn't working for me. Is anyone else having that issue?
  18. bhoopesh Donut Feb 27, 2015
    bhoopesh, Feb 27, 2015 :
    Wow ROM...I flashed it two days before and I can say it's awesome... Battery life is best on it. No other ROM has given me such battery life performance. Not even CM11S. Gr8 ROM I use Franco kernel over it. It's flawless......
    FXA and forid-786 like this.
  19. takeabyte Ice Cream Sandwich Feb 27, 2015
    19 and 25 were good for others, but I was getting a lot of idle battery drain, so today I just restored my nandroid backup and am back to 44S :)
  20. dylandelaaf Eclair Feb 27, 2015
    Im currently on 25. Seems ill be getting the same battery stats as I was getting on cm11s latest update(just over 6 hrs SOT). Might change as my battery adjusts. We'll see..
