What's using up my space?
  1. W1527921071156
    Cupcake Jun 18, 2018
    W1527921071156 , Jun 18, 2018 :
    am not sure of the root cause but I observed that after we deleting cached data immediately 'other' option is occupying the same storage which just released by freeing cache.
    any1 can help me on this
    srinivasan_v likes this.
  2. menon007
    Eclair Jun 18, 2018
  3. srinivasan_v
    Froyo Jun 18, 2018
    srinivasan_v , Jun 18, 2018 :
    This is exactly thy same problem I also have!
  4. srinivasan_v
    Froyo Jun 18, 2018
    I cleared some videos, but other ended up in taking up the space. This is seriously weird!
  5. Saralkarkee
    Donut Jun 18, 2018
    BCKTWLHLA and srinivasan_v like this.
  6. W1518165644549
    Donut Jun 18, 2018
    W1518165644549 , Jun 18, 2018 :
    Did u backup your phone data using OnePlus Switch app? I Did and Others folder was filled with 19gb.
    Vakil75 likes this.
  7. maciejsb
    Donut Jun 18, 2018
    maciejsb , Jun 18, 2018 :
    Every image (and video file) deleted from the DCIM/Camera directory is not actually deleted but it is moved to /Android/data/com.oneplus.gallery/files/recyclebin. After 30 days files are deleted automatically, of course you can delete these files earlier, either manually or by opening the standard gallery app and going to deleted images. I guess this is the reason for you issue. BTW, there is an app in Google Play called DiskUsage from Ivan Volosyuk which can precisely show you what is occupying your storage.
    Disclaimer: I own OnePlus 6, hope this apply to your device as well.
  8. srinivasan_v
    Froyo Jun 18, 2018
    Top notch!
    This is exactly I did, after a bit of search on the internet.. Even though we delete the files from traditional gallery, the files are actually residing as a residual in that location.
    I used SD Maid app and found the folder occupying the huge space.
    Here is the updated look..
  9. avinashadvani
    Jelly Bean Jun 18, 2018
    avinashadvani , Jun 18, 2018 :
    How did you delete, I cannot find deleted images in the gallery app i dont see any menu options at all..
  10. maciejsb
    Donut Jun 18, 2018
    Apps - Gallery - Collections and then on the bottom there is album called Recently deleted. The names can be a bit different because I don't know how it looks like in English Version of the OxygenOS. Or like I said, go to the dir and delete files manually.
    The files in the recycle bin dir have names different than the ones originally stored in Camera directory. But if you restore pictures from the Gallery app directly the strange names become the original plus the picture will be exactly the same as it was before the deletion (I have checked this by checking hashes (checksums)).
  11. maciejsb
    Donut Jun 18, 2018
  12. F_Terence_Quah_gSCv
    Ice Cream Sandwich Jun 18, 2018
    F_Terence_Quah_gSCv , Jun 18, 2018 :
    why can't it... official Facebook alone hoard data space of at least 500mb while it's apk alone only 40+mb....
    didn't count games yet.
    do a count on what u installed and u see why.
  13. Dev_senapati
    Donut Jun 18, 2018
    Dev_senapati , Jun 18, 2018 :
    hey I guess u would have Missed some steps or you would have interpreted my statement wrongly somewhere coz i had this same issue and yes i found which folder was having so much of data and it got solved for me..
  14. Dev_senapati
    Donut Jun 18, 2018
    i will give u one more idea u have to give a bit of effort obviously coz once this gets solved u will be relaxed forever go to file manager>>internal storage here you will find may folders one by one check the properties or size of each folder in a sequence you'll be able to find which folder is having large chunk of data in GBs believe it might be either oem_log folder or OnePlus folder..just do this much first
  15. srinivasan_v
    Froyo Jun 18, 2018
  16. srinivasan_v
    Froyo Jun 19, 2018
