WhatsApp Audio Note Volume Issue
  1. mwaqasaziz
    Cupcake Sep 21, 2017
    mwaqasaziz , Sep 21, 2017 :
    Whenever I record an audio note in OP5, The volume is too low that I need to stick my ear to the speaker to listen to my own voice despite of the fact the volume is full.
    Any solution guys ?
    G_Sharon_Chung_kOow likes this.
  2. mwaqasaziz
  3. AdrianW94
    Donut Sep 21, 2017
    AdrianW94 , Sep 21, 2017 :
    have you tried the voice recorder to be certain it is limited to the VN on WhatsApp?
  4. mwaqasaziz
  5. dennizbiz
    Gingerbread Sep 22, 2017
    dennizbiz , Sep 22, 2017 :
    Is it the WhatsApp media file that is low in quality? Also check your volume media settings during playback.
    Run some test with other devices just to be sure.
  6. mwaqasaziz
    Cupcake Sep 22, 2017
    mwaqasaziz , Sep 22, 2017 :
    No this is the voice note that you record on the spot and send it to the other person. do you guys face the same issue ?
  7. mwaqasaziz
    also, I have checked the recorder and volume levels as well. All are working fine. it's just the Whatsapp audio voice note that is the problem? Is there a way to communicate it to the developers? I know it may not be a big issue for many but its a bug afterall
  8. dorondil
    Cupcake Jan 18, 2018
    dorondil , Jan 18, 2018 :
    I have same issue,
    I get voice message on whatsapp and can hear very very low, must stick my head to the microphone area to try to hear anything,
    phone is not on silent and all volumes are to the maximum ..
  9. jarturoar
    jarturoar , Jan 18, 2018 :
    I am having the same issue with a 3T, only with WhatsApp, music playback is ok and if I use a headphone it is fine as well, but audio notes in speaker are almost mute.
  10. Alitop__xD
    Cupcake Mar 1, 2018
    Jumpi1234 likes this.
  11. joel619
    Eclair May 24, 2018
    joel619 , May 24, 2018 :
    I'm facing the same issue with OnePlus 6!!! Need help to fix this. I use this a lot.
  12. lakshaykapoor99
    Honeycomb May 24, 2018
  13. koikkeli
    Donut Jun 19, 2018
  14. Richfield Kirthan
    Gingerbread Jun 19, 2018
  15. Vuoshino
    Cupcake Jul 4, 2018
    Vuoshino , Jul 4, 2018 :
    Same issues with whatsapp rec and autofocus in the whatsapp cam... I think this will never fix because was a problem of the oneplus 1... Very unprofessional thing from oneplus
