WhatsApp camera issue via OnePlus 7T
  1. Roei.e
    Honeycomb Aug 4, 2021
    Roei.e , via OnePlus 7T , Aug 4, 2021 :
    WhatsApp camera crashes and also lagging, take for ever to take a pic. Fix.!
  2. pablofg1978
    Head Moderator Head Moderator Aug 4, 2021
    Best Answer
    pablofg1978 , Aug 4, 2021 :
    OnePlus can't fix third parties apps.
    But if you are sure about it, use the feedback section on the community app to submit it directly to oneplus
  3. pablofg1978
    Try to clean the whatsapp cache. If that doesn't work, contact whatsapp developers
  4. Roei.e
    I tried, and jt does not WhatsApp, it's OnePlus. Android 10 it wasn't. And other phones works fine with WhatsApp
  5. Roei.e
    So how do you explain that in android 10 it was fine? And other phones works good with it.
    OnePlus ruin everything in this android 11
  6. pablofg1978
    WhatsApp works fine on my device running Android 11.
    Apps are also updated, and some times also they break things that was working before.
    Check on the playstore if there is a newer version available
  7. Roei.e
    Because you probably don't have 7 series, android 11 on 7 series is bas, check all the posts about this issue, I just talked with OnePlus support and they told me to Post here
  8. pablofg1978
    My wife has a 7 pro.
    No issues with whatsapp
  9. B_Wrath
    Nougat Aug 4, 2021
    B_Wrath , Aug 4, 2021 :
    @dsmonteiro the CS are at it again. Please escalate this.
    I don't know why they help asking to create threads here in the forums.
  10. dsmonteiro
    Community Consultant Staff Member Aug 4, 2021
    dsmonteiro , via OnePlus 9 Pro , Aug 4, 2021 :
    The Customer Support rightfully directs users to the Community's feedback section to submit software related bugs, which then get treated as bug reports internally.
    This is one of such cases. I've gone through the script with @Tom B. in the past and it's correct and straightforward. Unfortunately, some users misinterpret it and post and regular threads.
    The cases where users are being incorrectly sent to the forums are also shared with the CS team for future improvement, but that's not the case here.
    Tom B., McJader and the_o2 like this.
  11. B_Wrath
    Nougat Aug 4, 2021
    Ah. I get it. Maybe we should keep the "create thread" inside specific forum pages in the app, and hide it in the main page. Just like the website. But that's a whole different subject.
