whatsapp incoming call notification
  1. aarthi_ns_
    Cupcake May 5, 2020
    afrom89 likes this.
  2. madhuvijay
    Cupcake May 16, 2020
  3. the_o2
    OnePlus 9 Series Expert Community Expert May 16, 2020
    the_o2 , May 16, 2020 :
    Check the notifications settings for the whatsapp and disable the battery optimization for the WhatsApp as well.
  4. madhuvijay
    madhuvijay , via OnePlus 6 , May 16, 2020 :
    I have already set it to don't optimize but still the issue remains .
  5. the_o2
    Gaming Mode or DND is not activated?
    Are you getting the notifications when the screen is on?
  6. madhuvijay
    I have not activated both and I get the notification when the screen is on.
  7. the_o2
  8. Oxcart
    Cupcake Jun 2, 2020
    Oxcart , Jun 2, 2020 :
    I also face this issue on 7T Pro, I have been chatting on LiveChat about fixes but nothing has worked so far (including app preference reset). Currently doing a hard reset, but I doubt that will fix this.
    Looked online and so many seem to complain about it, but its just the usual fixes of Battery Optimiser, notification settings and nothing seems to work.
    I noted on mine that it seems worse when using cellular data, but it can happen on either WiFi or cell.
  9. X1604551323137
    Cupcake Apr 15, 2021
    X1604551323137 , via OnePlus Nord , Apr 15, 2021 :
    Try to check the battery optimization option.
    Go to settings
    Apps and notifications
    Apps info
    Whatsapp
    Advanced
    Battery Optimization
    Then select Intelligently control(dont select optimize)
    If problem not solved pls check the notification settings of whatsapp in apps info
  10. KaranFafat
    Gingerbread Apr 16, 2021
