WhatsApp issue
  1. F_Sanjay_Kukreja_WOzQ
    Donut Dec 25, 2017
    F_Sanjay_Kukreja_WOzQ , Dec 25, 2017 :
    over the last couple of days, have been facing this issue with WhatsApp that unless I open the application the messages don't get downloaded neither do I get any notification about new messages.anyone else facing similar issue? any solutions? pls help, thanks in advance.
  2. Qayyumbydefault
    Gingerbread Dec 25, 2017
  3. Qayyumbydefault
  4. tanmay jain 844
    Froyo Dec 25, 2017
    tanmay jain 844 , Dec 25, 2017 :
    I've been facing similar kind of problems , disable the doze mode to get rid of it . battery optimisation are active for WhatsApp aswell when se turn on doze mode.
  5. I1512587383431
    Cupcake Dec 25, 2017
    I1512587383431 , Dec 25, 2017 :
    create a WhatsApp widget in shelf of your OnePlus launcher and forget about it.... it'll work perfectly fine.....!
  6. J1508488204938
    Froyo Dec 25, 2017
    J1508488204938 , Dec 25, 2017 :
    I've had the same problem immediately after updating to Oreo , a simple uninstall and reinstall brought everything back to normal.
  7. F_Sanjay_Kukreja_WOzQ
    Donut Dec 26, 2017
    F_Sanjay_Kukreja_WOzQ , Dec 26, 2017 :
    no such thing installed on my phone..this problem just started cropping up recently..
  8. F_Sanjay_Kukreja_WOzQ
    Donut Dec 26, 2017
    Are you mentioning about the battery optimisation setting, i see that whatsapp is in optimized status but was wondering if it was working fine earlier, there should be no reason for it to stop working now...
  9. F_Sanjay_Kukreja_WOzQ
    Donut Dec 26, 2017
    even i have updated to oreo about a month back , but this problem started cropping up only a couple of days back..wil try the uninstall and reinstall solution as well..
