2
WhatsApp not receiving messages until I manually launch it?
  1. ashutoshmn Ice Cream Sandwich Jan 24, 2015
    ashutoshmn, Jan 24, 2015 :
    go to settings->apps
    in downloaded apps, find whatsapp and tap on it.
    Now check the box saying receive noifications.
  2. Thimo Jelly Bean Jan 24, 2015
    Thimo, Jan 24, 2015 :
    Mhmmhmhmhm...
    Did you also check if your notifications in whatsapp are on?
    Oh ye, can you see it connecting when you OPEN the app? Or are the messages already loaded?
  3. xGho0sT Eclair Jan 24, 2015
  4. eranm5 Jelly Bean Jan 25, 2015
    eranm5, Jan 25, 2015 :
    Only when I open the app. It starts connecting and shows the messages about 5 seconds later.
  5. ayy1892 Honeycomb Jan 25, 2015
    ayy1892, Jan 25, 2015 :
    go to applications>running apps and see whether whatsapp is running or not...if it's running then you should be able to receive messages.
  6. eranm5 Jelly Bean Jan 25, 2015
    It is on, but I still don't receive notifications.
  7. ashutoshmn Ice Cream Sandwich Jan 25, 2015
  8. vsbrt Cupcake Jan 25, 2015
    vsbrt, Jan 25, 2015 :
    go to settings>app and see the uptime. if it is lass than 1 minute, then that app is being auto killed by the android system itself. this issue happens often on my moto g also. the best solution for this problem is, open whatsapp and minimize it and never clear it from the overview.
  9. eranm5 Jelly Bean Jan 25, 2015
    The WhatsApp service is running for 17 hours now, but It still doesn't receive new messages until I turn it on.
    A1529776939131 likes this.
  10. sid777 Donut Jan 25, 2015
  11. fgrhuhrg Ice Cream Sandwich Jan 25, 2015
    fgrhuhrg, Jan 25, 2015 :
    im having the same problems, but i thought it was just my WiFi. clearly not, i really need a solution
  12. theSprintman Honeycomb Jan 25, 2015
    theSprintman, Jan 25, 2015 :
    I have the same issue, I receive notifications but NO sound (ringtone). I use the latest nightly of CM12.
  13. shaadfaizel Eclair Jan 25, 2015
    shaadfaizel, Jan 25, 2015 :
    dont worry about it..It will be alright within nxt update.....!
    Did u install any app for saving battery or memory(clean master or battery saver...etc)??
  14. shaadfaizel Eclair Jan 25, 2015
    Go to whatsapp settings...
    Notification settings
    Tick~Play sounds while receiving messages
  15. Hanson Lee Lollipop Community Expert Jan 25, 2015
    Hanson Lee, Jan 25, 2015 :
    Same problem with CyanHacker.
    It's not the problem of notifications, it's the receiving messages part that's the problem.
    eranm5 likes this.
  16. MCMXCIVR Ice Cream Sandwich Jan 25, 2015
    MCMXCIVR, Jan 25, 2015 :
    I've had this problem with more apps. On the Jiayu G4 running MIUI with almost all of my apps and with the One using the mail.com app.
  17. Hanson Lee Lollipop Community Expert Jan 25, 2015
  18. theSprintman Honeycomb Jan 25, 2015
    I already did that. It plays no sound on incoming messages, it only vibrates.
    #38
  19. firewire2035 KitKat Jan 25, 2015
    firewire2035, Jan 25, 2015 :
    wasapp settings
    privacy guard settings
    settings > accounts > wasapp
    greenify, batteryguru, etc.
    #39
  20. Thimo Jelly Bean Jan 25, 2015
    Thimo, Jan 25, 2015 :
    What version are you running by the way? And did it occur on older versions?
    #40
