Whatsapp web scanner problem One Plus Nord 2 via OnePlus Nord 2
  1. YasasviSunkara
    Cupcake Sep 22, 2021
    YasasviSunkara , via OnePlus Nord 2 , Sep 22, 2021 :
    Not able to scan QR code in whatsapp web how much every I try.
  2. pablofg1978
    Head Moderator Head Moderator Sep 22, 2021
    Best Answer
    pablofg1978 , Sep 22, 2021 :
    You can't use a qr reader, it won't work.
    You need to use the whatsapp app.
    Go to the 3 dots menu, registered devices, register a new device. Scan the code there.
    This is why you can't post on other sections
    https://forums.oneplus.com/threads/...red-faster-introducing-starting-point.812193/
  3. YasasviSunkara
  4. pablofg1978
    Hello there,
    I moved your thread to a more appropriate section. Introduce yourself section is not meant for this type of content.
    Are you using a qr code scanner to read it or the whatsapp app?
  5. YasasviSunkara
    Sorry. Thanks for moving the thread. I wasn't able to post anywhere else for some reason.
    I tried using Google lens and that also resulted in just google images popping up.
    I used the scanner from. Whatsapp and there is no response. I'm not sure if I'm doing anything wrong.
  6. YasasviSunkara
  7. pablofg1978
    Contact the app developer and submit a bug report
