when will one plus 7 pro 5g variant comes to India ??
  1. G_Abdul_Basith_TMMS
    Eclair Jun 1, 2019
  2. camohan
    Marshmallow Moderator Jun 1, 2019
    camohan , Jun 1, 2019 :
    Not in the near future. 5g is expected to start buzzing in India by 2020. Long way to go.
  3. G_Abdul_Basith_TMMS
    Eclair Jun 1, 2019
  4. camohan
    When 5g can be used in India.
  5. Sargo
    Ice Cream Sandwich Jun 1, 2019
    Sargo , Jun 1, 2019 :
    for what
    its identical to the regular one and costs a lot more
    probably will come by the next gen with inbuilt 5g rather than seperate modem
  6. Matt 80
    Lollipop Jun 1, 2019
    Matt 80 , Jun 1, 2019 :
    But you have no access to 5G in your country, so what's the point in buying it? Buy the standard 7 Pro and save some money.
    Android450 and toastytoast1234 like this.
  7. G_Abdul_Basith_TMMS
    Eclair Jun 2, 2019
  8. G_Abdul_Basith_TMMS
    Eclair Jun 2, 2019
    G_Abdul_Basith_TMMS , Jun 2, 2019 :
    is it worth upgrading from one plus 6 ?
  9. toastytoast1234
    Marshmallow Jun 2, 2019
    toastytoast1234 , Jun 2, 2019 :
    As mentioned above, do you have 5G in India?
    If you're not based in India at the moment, only you can decide what 5G is worth to you.
    Matt 80 and Android450 like this.
  10. camohan
    Marshmallow Moderator Jun 2, 2019
    camohan , Jun 2, 2019 :
    You should probably sleep it's 4.30 am when you typed. Things can appear tricky. 5g is not there in India.
    Budruel and toastytoast1234 like this.
  11. toastytoast1234
    Sleep is for wimps, and how dare you assume xe's assigned working timezone.
    Budruel and Android450 like this.
  12. D1560253674163
    Cupcake Jun 11, 2019
  13. Gav_W86
    Starting Point Expert Community Expert Jun 11, 2019
    Gav_W86 , Jun 11, 2019 :
    no, only the specific OP 7 Pro 5G. That is currently only available via EE in the UK (who have a 5G network running).
  14. Budruel
    KitKat Jun 11, 2019
    Budruel , Jun 11, 2019 :
    Have you read the thread, or not?
