where can I get tempered glass for one plus 7 pro
  1. malav.jobanputra
    Cupcake Jul 4, 2019
  2. Dresa91
    User of the Year 2016 Jul 4, 2019
    Dresa91 , Jul 4, 2019 :
    for example Amazon.
  3. malav.jobanputra
    Cupcake Jul 4, 2019
    jdfromtexas likes this.
  4. Liehjan
    Lollipop Jul 4, 2019
    Liehjan , Jul 4, 2019 :
    There is no original one, as oneplus don't sell one!
  5. Dresa91
    then: Store or webshop
    malav.jobanputra likes this.
  6. gcocucci
    Nougat Jul 4, 2019
  7. F_Niall_Love_bRvB
    Froyo Jul 4, 2019
  8. F_Niall_Love_bRvB
    Froyo Jul 4, 2019
  9. Miguel_Tavora
    Donut Jul 5, 2019
    Miguel_Tavora , Jul 5, 2019 :
    I've bougth the Whitestone Domeglass. perfect fit. Easy installation. It's expensive, but it's the best.
    Ernest 1ca likes this.
  10. G_Sridhar_Bheeman_lJRH
    Eclair Jul 7, 2019
    G_Sridhar_Bheeman_lJRH , Jul 7, 2019 :
    so far in India haven't come across any good screen protector yet. But came across this one which fits fine on the edges but leaves a bit gap from the top/ bottom. Still satisfactory though, the tough part is the installation: make sure you cover the speaker grills and wipe the liquid GENTLY before curing/ hardening the UV solution.
    link: Kavacha Oneplus 7 Pro Tempered Glass, Full Adhesive UV Glue Curved Edge to Edge Case Friendly Full Coverage Tempered Glass Film Protective Cover for Oneplus 7 Pro https://www.amazon.in/dp/B07SQZMD7H/ref=cm_sw_r_cp_apa_i_xLsiDb9TV0QYV
    pros:
    Borderless
    edge to edge
    full glue
    touch feedback is excellent
    fingerprint works well
    case friendly: i am using carbon bumper case
    cons:
    installation is messy
    will keep you updated if i find a better one
  11. DarkFateRider
    Cupcake Oct 10, 2019
    DarkFateRider , Oct 10, 2019 :
    any suggestions. I have tried the case u tempered glass uv one. but it has problems in getting it installed on the edges leaves air bubbles is that a problem with the person installing or the product itself?
