Where is the proximity sensor in OnePlus 7?
  1. femiuex
    Ice Cream Sandwich Aug 8, 2019
    femiuex , Aug 8, 2019 :
    New software update disabled this.
  2. eshwarprithvi
    Cupcake Aug 9, 2019
    eshwarprithvi , Aug 9, 2019 :
    is there any other way to access this?
  3. femiuex
    Ice Cream Sandwich Aug 9, 2019
    femiuex , Aug 9, 2019 :
    Not at the moment.
  4. cruzAD
    Gingerbread Aug 18, 2019
    cruzAD , Aug 18, 2019 :
    No, OnePlus 7 series have NO proximity sensor, only a so called "virtual" one.
  5. Agnishchakra
    Cupcake Aug 27, 2019
    Agnishchakra , Aug 27, 2019 :
    As far as i experienced, the sensor seems to be non functional if i block the front camera completely. So i hope they are using the front camera. Though i learnt that they are using a software based proximity sensor.
  6. tommygooden
    Froyo Aug 27, 2019
    tommygooden , Aug 27, 2019 :
    I know I'm late but it actually doesn't have a proximity sensor. It has a virtual contraption that tries to figure out proximity to things. It messed up my navigation when I just got my phone jumped in my car and tried to navigate somewhere. Navigation was so slow and laggy. It's okay now thanks to the AI element that's being used. But no it doesn't have a sensor.
  7. Matt 80
    Lollipop Aug 27, 2019
    Matt 80 , Aug 27, 2019 :
    Yeah I heard about the virtual sensor a couple of weeks ago, I assumed at the time oneplus would have used the same method as Samsung (under display sensor in the s10) but instead they decided to use some half baked system which has caused problems for many users.
    tommygooden likes this.
  8. Nimish Pandey
    Cupcake Nov 21, 2019
    Nimish Pandey , Nov 21, 2019 :
    There You go it is a under display sensor (btw the pic is of Oneplus 7T but in case of Oneplus 7 it will be similar)
  9. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Nov 21, 2019 :
    Samsung had some issues too though. Don't recall what sensor they used though
  10. I1557911384926
    Froyo Nov 21, 2019
    I1557911384926 , Nov 21, 2019 :
    *#808# does nothing.
    As I have found out *#808# doesn't work anymore as they removed it on Oxygen 9.5.11
    cruzAD likes this.
  11. parag008
    Ice Cream Sandwich Nov 22, 2019
    parag008 , via OnePlus 7 Mirror Gray , Nov 22, 2019 :
    i see. so no more tinkering with the internal hardwares i presume.
    cruzAD likes this.
  12. Varun1225
    Gingerbread Jan 12, 2020
  13. Darkmix
    Eclair Jan 12, 2020
    Darkmix , Jan 12, 2020 :
    its somewhere here, just download lux ligth mater and cover screen there with something and when "lux" shows 0 then start uncover it till "lux" will increase
  14. Pranay Chidura
    Cupcake Jan 25, 2020
    Pranay Chidura , Jan 25, 2020 :
    Yes, proximity sensor is under the screen. You can check by,
    1)Turn off your screen
    2) Take another mobile and open camera
    3) check the phone screen through the camera
    The purple color light will be glowing below the front camera is nothing but proximity sensor. You can check any phone by this process.
  15. P1586878264870
    Cupcake Jun 26, 2020
    P1586878264870 , Jun 26, 2020 :
    *#808# is not working. So that means they removed engineering mode ? I'm using OnePlus 8 . There are some issues regarding gyroscope. I should calibrate. Please help me to solve the issue.
  16. Artemus.
    Nougat Jun 26, 2020
    Artemus. , Jun 26, 2020 :
    Wrong subforum.
  17. parag008
    Ice Cream Sandwich Jun 30, 2020
    parag008 , via OnePlus 7 , Jun 30, 2020 :
    i think oneplus removed the users ability to enter engineering mode now. I'll say that you should get your device checked at a service center for any major issue if there is one.
