Where to find oneplus 7 pro battery replacement via OnePlus 7 Pro
  1. Saifu147
    Cupcake Sep 27, 2020
    Saifu147 , via OnePlus 7 Pro , Sep 27, 2020 :
    I was charging my op 7 pro with Portable power bank. And the battery life is reduces from 8 hours of screen on time to 5 hour 30 mins avg. I was thinking if maybe i co6uls replace the battery but I'm unable to find a bettery on internet. If anyone can help me out please
  2. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Sep 27, 2020
    Best Answer
    Liehjan , Sep 27, 2020 :
    Charge your phone over night with the original charger... If you use a powerbank a lot then it cuts off the charge when phone hits 100% and don't optimize
    Artemus and A1595176314393 like this.
  3. Liehjan
    OnePlus service center... But the issue is probably not your battery
  4. Saifu147
    I'm from Pakistan and we only have phones that are being imported by few dealers there's no official store in Pakistan. And if the issue is not the battery then what else?
    Like yesterday i saw my battery on 70% and after literally like 15 mins it had dropped to 65% while it was in my pocket, just the mobile data was turned on and there was n new notification as well
  5. Liehjan
    A battery should be good for 2 years if charged one a day... You can do the match if you need a replacement or not... Have you tried calibrating the battery?
    Artemus likes this.
  6. Saifu147
    Nope. Can you guide me how to calibrate it? I mean how does it works. Help me out please
  7. Saifu147
    Okay. Will try that. I hope i don't have to replace the battery. The one is used for 4 months only
    Liehjan likes this.
