Where to replace oneplus 7 pro battery in Germany? via OnePlus 7 Pro
  1. N1558705547004
    Eclair Jun 10, 2021 at 7:11 PM
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Jun 10, 2021 at 7:14 PM
  3. Artemus.
    Community Hero 2020 Jun 10, 2021 at 7:57 PM
    Artemus. , Jun 10, 2021 at 7:57 PM :
    You can also post a screenshot of your battery stats and avoid replacing the battery altogether.
    otto2, Aaron2017 and Dresa91 like this.
  4. N1558705547004
    Eclair Jun 10, 2021 at 8:47 PM
    otto2 likes this.
  5. Artemus.
    Community Hero 2020 Jun 11, 2021 at 1:21 AM
    Artemus. , Jun 11, 2021 at 1:21 AM :
    Settings > Battery > View detailed usage. Take a screenshot of this screen.
  6. N1558705547004
    Eclair Jun 11, 2021 at 10:07 PM
  7. Artemus.
    Community Hero 2020 Jun 11, 2021 at 11:16 PM
    Artemus. , Jun 11, 2021 at 11:16 PM :
    It'll show us what your battery life is like. Usually you don't need a battery replacement unless it's damaged somehow. IF your battery life is draining quickly, it's usually caused by apps you're using and not the battery needing a replacement.
    otto2 and E1558912633684 like this.
  8. N1558705547004
    Eclair Jun 14, 2021 at 5:31 PM
    N1558705547004 , via OnePlus 7 Pro , Jun 14, 2021 at 5:31 PM :
    My use for my phone is the same... The only thing that is different is oneplus sw updates and shorter screen on time compared to last year and the year before it.
    That is why I asked where to replace my battery.
    Do you believe that battery retain its capacity after 2.5 years of usage?
  9. Artemus.
    Community Hero 2020 Jun 14, 2021 at 11:55 PM
    Artemus. , Jun 14, 2021 at 11:55 PM :
    Can you take some screenshots of your battery graph?
    otto2 likes this.
