Which Case is best for Oneplus 7 Pro in following link?
  1. Sanyam Mehta
    Eclair Jul 8, 2019
  2. tuanv1966
    Froyo Jul 8, 2019
    tuanv1966 , Jul 8, 2019 :
    I really like the clear one. It's simple, it's grippy, and allows me to see the blue in the back. I wished it was clearer. I did order a magnetic frame case on Ebay, but will return it. It's too slippery. The frames are made of metal.
  3. Afzal Khan
    KitKat Jul 8, 2019
    Afzal Khan , Jul 8, 2019 :
    If you didn't read it properly- It's actually true.
    There is really no better Case for the OnePlus 7 Pro than the first-party OnePlus Protective Case. Not only does it fit the phone like a glove, it also perfectly matches its style with two distinct finishes: Carbon and Sandstone. The case also has perfect cut-outs for the buttons and the pop-up selfie camera.
  4. Deactivated User
    Jul 8, 2019
  5. Sanyam Mehta
    Eclair Jul 9, 2019
    Sanyam Mehta , Jul 9, 2019 :
    Grippy means, 'll go with dbrand?
  6. #6
