which is best rom for one plus two???
which is best for one plus two???
Poll closed Mar 17, 2017.
  1. cyanogenmod 13
    59.4%
  2. paranoid (AOSPA) 6.0.1
    27.4%
  3. exodus 6.0.1
    2.8%
  4. oxygen os 3.0.2
    10.4%
  1. sfomin
    Nougat Aug 18, 2016
    sfomin , Aug 18, 2016 :
    yep. good thing its free malware[​IMG] would be even worse if it was paid malware[​IMG]
    Chugz likes this.
  2. Chugz
    Ice Cream Sandwich Aug 18, 2016
    Chugz , Aug 18, 2016 :
    OK my boy, I guess you have no problem with me coming into you house uninvited and throwing away all your illegal stuff like music and movies?
  3. spencer1620
    Ice Cream Sandwich Aug 19, 2016
    spencer1620 , Aug 19, 2016 :
    Well "My boy" you won't find any in my household but that could change as if you are ok with theft can I come and take some of your things?
  4. Chugz
    Chugz , Aug 19, 2016 :
    Sure while you're taking my things, I'll also list them on eBay for far more value than they are actually worth. So I'll list a chocolate bar for €10 instead of €1. Ya' know.
    Oh and I have an unlimited supply of chocolate bars, so feel free to take as many as you want - it's not as if you were going to pay for them in the first place.
    spencer1620 likes this.
  5. joceguerau
    Cupcake Aug 19, 2016
  6. patel lav
    Gingerbread Aug 20, 2016
    patel lav , Aug 20, 2016 :
    but in performance and app opening speed in normal and multitasking is oxygen os is able to defeat cyanogenmod ????
  7. acharyarev
    Ice Cream Sandwich Aug 20, 2016
    acharyarev , Aug 20, 2016 :
    CM is Very Smooth for daily use. been using it for a week. only thing i miss from OOS is its Dirac sound was pretty good and was working well with Poweramp player. other than that some of them are reporting GPS lock issue (Though i am not facing any for regular usage.
  8. Opseli
    Cupcake Aug 20, 2016
  9. patel lav
    Gingerbread Aug 21, 2016
    patel lav , Aug 21, 2016 :
    guys i got a problem!!! i am on cm 13 16-8 build and i am facing to much hanging issuses on my musicplayer. i used different music players like musixmatch,google play music,etc. but still i face same problem in all. so any fixes or anybody can help me to get rid from this?
    thnx for your kind support:):)
  10. Dhruvism
    Gingerbread Sep 12, 2016
    Dhruvism , Sep 12, 2016 :
    So far I'm counting on Resurection Remix,the latest version seems to have done wonders in terms of Battery and performance
  11. Vinay_
    Gingerbread Sep 13, 2016
    Vinay_ , Sep 13, 2016 :
    For me it's CM13 still no stable build
    But the nightly doing its job good
    No lag on the build I'm using
    Battery is bit better than OOS
    Pre Rooted
    And huge customization
    Currently I'm using CM and happy with the performance
  12. VirtuosoLoki
  13. Sehej Jain
    Ice Cream Sandwich Sep 15, 2016
  14. jssonf1984
    Honeycomb Sep 15, 2016
    jssonf1984 , Sep 15, 2016 :
    I am currently on OOS 3.1.0 and am very happy with it. I have used exodus and it's solid as a daily driver, maybe better than some oem roms. Very professionally handled I have never had a issue with the "malware". Cm 13 is pretty good but it's nightly so something that was working fine could be broken on the next update too much work for me. Just my 2 cents you definitely need to try a few out to see what works for you. That is the beauty of having custom roms.
  15. Shubham_007
    Cupcake Sep 15, 2016
  16. sachin.96.agarwal
    Gingerbread Sep 15, 2016
    sachin.96.agarwal , Sep 15, 2016 :
    U can also try hydrogen OS if u wanna stick to stock. Great battery life, I myself get around 4hr 30min screen on time and it's also got a nice UI. If u wanna change to custom then cm 13 is best
  17. Nvds
    Froyo Sep 15, 2016
