While downgrading from Oxygen os 11 to Oxygen os 10 i faced this problem. Need help to solve this. via OnePlus 8 Pro
  1. F_BBlu_Paul_XiqJ
    Cupcake Sep 19, 2020
  2. W1508491554407
    Gingerbread Sep 19, 2020
    KNM REDDY likes this.
  3. Riobijoy
    Eclair Sep 19, 2020
  4. dipankar9955
    Cupcake Sep 20, 2020
  5. the_o2
    User of the Year 2018 Sep 20, 2020
    Tee_Eee_Bee and SteveCP like this.
  6. SteveCP
    Jelly Bean Sep 20, 2020
    SteveCP , via OnePlus 8 Pro Onyx Black , Sep 20, 2020 :
    This has nothing to do with the file name, he hasn't used the correct roll back firmware.
  7. F_BBlu_Paul_XiqJ
    Cupcake Sep 22, 2020
    SteveCP likes this.
  8. F_BBlu_Paul_XiqJ
    the_o2 likes this.
  9. jaichoudhary512@
    Cupcake Oct 4, 2020
  10. Jitendra Ravi
    Eclair Oct 8, 2020
    Jitendra Ravi , via OnePlus 8 Pro , Oct 8, 2020 :
    Any one tell me please
    How can fixed it and how can install oxygen os 10 or how can downgrading......
  11. Tee_Eee_Bee
    Ice Cream Sandwich Oct 8, 2020
    Tee_Eee_Bee , Oct 8, 2020 :
    Make sure you follow the instructions in the first post of the Open Beta 1 thread (included below) and download the correct version for your device/region. Also, as stated in the instructions, roll back will wipe your device, so back everything up first.
    https://forums.oneplus.com/threads/...eplus-8-series.1296568/page-214#post-22148701
    Note: OBT is open beta, MP is Android 10
    OBT to MP rollback guide—via Local OTA update
    Note: This upgrade method will erase all the contents of the phone, please be sure to backup first
    1. Download the latest ROM upgrade zip package from the specified server
    2. Copy the Rollback package to the phone's internal storage, and remove the '.jar' file name extension if present so that the file ends in '.zip'
    3. Go to Settings -> System -> System Updates -> Click top right icon -> Local upgrade -> Click on the corresponding installation package -> upgrade -> System upgrade completed to 100%
    4. After the upgrade is complete, click Restart
    5. Update successful
    Want to go back to MP? Download the Rollback package from the links below:
    Download links for OnePlus 8:
    OnePlus 8 NA Version
    OnePlus 8 IN Version
    OnePlus 8 EU Version
    Download links for OnePlus 8 Pro:
    OnePlus 8 Pro NA Version
    OnePlus 8 Pro IN Version
    OnePlus 8 Pro EU Version
  12. Jitendra Ravi
    Eclair Oct 9, 2020
    Jitendra Ravi , via OnePlus 8 Pro , Oct 9, 2020 :
    This method is not work
    So what i do...
    I want to change, hydrogen os 11 to oxygen os 10 , so what can do...
    Any other method...
  13. Tee_Eee_Bee
    Ice Cream Sandwich Oct 9, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Oct 9, 2020 :
    Try this, it should be a roll back package for Hydrogen OS to A10:
    The following are the downgrade packages available for downgrading to the stable version of Hydrogen OS 10 (Android 10):
    OnePlus 8
    http://download.h2os.com/OnePlus8Pr...all_2005301412_downgrade_336a08ea32aa4c88.zip
    OnePlus 8 Pro
    http://download.h2os.com/OnePlus8Pr..._OTA_0110_all_2009112319_2084a2d916f34549.zip
    They are from here:
    https://www.gizchina.com/2020/09/17...-os-android-11-public-beta-now-available/amp/
    I think you should then be able to download and install the latest 8 Pro software from your region's OnePlus support page > Software Upgrade.
  14. Jitendra Ravi
    Eclair Oct 9, 2020
    Sir i want to change HYDROGEN OS 11 in to OXYGEN OS 10
    hydrogen to oxygen.....
    Not hydrogen os to hydrogen os
    So give any method....
  15. Bobbie63
    Marshmallow Oct 9, 2020
    Bobbie63 , Oct 9, 2020 :
    Download the file, move it in the root directory, so not in a folder
    Install it in recovery mode.
    that’s what I would try. Don’t know if this would work with hydrogen but I’d guess this would work
    al at your own risk
    Edit:
    I saw you want to go back from Hydrogen 11 to Oxygen 10 so this probably won’t work either. You’ll have to use TWRP I guess
