10
Who is NOT having a problem with 4.0.2 and what did you do?
  1. TheBlack_Swordsman
    Gingerbread Jan 22, 2017
    TheBlack_Swordsman , Jan 22, 2017 :
    Yes you can, you can only do this on the first five toggles and before you fully extend the bar.
    Like at this point.
  2. G_Rajat_Nanda_Advocate_L
    Cupcake Jan 22, 2017
  3. bonati
    Donut Jan 22, 2017
  4. matrixn
    matrixn , Jan 22, 2017 :
    no problems so far...one thing I noticed...they fixed automatic brightness...so far after 2 days I did not found any glitches...I'm glad they fixed it cause was annoying...thanks OnePlus!! keep it up!
  5. Egytk
  6. teja2495
    Eclair Jan 22, 2017
    teja2495 , Jan 22, 2017 :
    VOLTE is not working for me after the update.. did anyone else face this issue?
  7. takuarc
  8. kushalpuri
    Donut Jan 22, 2017
  9. G_Thorsten_Schmädel_xvD
    Froyo Jan 22, 2017
  10. F_Lionel_Kitio_Donfack_P
    F_Lionel_Kitio_Donfack_P , Jan 22, 2017 :
    Me too
  11. cssoz
    Honeycomb Jan 22, 2017
    cssoz , Jan 22, 2017 :
    Factory reset. Get all apps and settings back (didn't used restore from Google) wiped cache
  12. G_tarun_kalra_PGgq
    G_tarun_kalra_PGgq , Jan 22, 2017 :
    Thanks a lot
  13. Oyesethi
    Oyesethi , Jan 22, 2017 :
    No issues in phone.. Only the Camara quality is worsen and Front camera is a disaster now in low light.. All hazzy pics.. Anyone else have such issue?
  14. niravnk
    niravnk , Jan 22, 2017 :
    I am having issues with camera using front camera.
    It goes into timer mode when I switch to front camera. I tried changing it but still next time when I open camera app, it goes into timer mode.
    I dont know whether its a feature or a bug.
    [e]1f602[/e][e]1f602[/e]
  15. Rubens Jr.
    Donut Jan 22, 2017
  16. aashman
    aashman , Jan 22, 2017 :
    [IMPORTANT]
    I have the update an no issues. Here's his to accomplish this:
    - buy the phone from OnePlus
    - wait for OTA to be available in your area through Settings > System Updates
    - install with more than 50% battery and restart to install
    Some key points to take away from this:
    - patience is key. WAIT for the update notification to update
    - DO NOT use VPN to get the updates quicker
    - ROOTING/SIDE LOADING is not required
    - patience is key. Your phone will not die because you don't have the latest update from 5 days ago
    Hope this helps others.
  17. F_Jagatbir_Singh_Saluja_
  18. rajeevdb
    Froyo Jan 22, 2017
    rajeevdb , Jan 22, 2017 :
    No problem so far working very smooth... Thanks OP team for the updates and efforts
  19. krazor8x
    Eclair Jan 22, 2017
    krazor8x , Jan 22, 2017 :
    I haven't had any issues, both Sims work(us) and all feature work except a couple apps that were optimized for nougat
  20. arefim
    arefim , Jan 22, 2017 :
    No issue. Standard update through OTA. No reset/ flash. Working absolutely fine. I am using 3T 128GB.
